Results 1 to 28 of 28
Thread: Tp motors
    Apr 2011
    oh
    1,109
    Default Tp motors
    Two TP Motors for sale , 5660 10D 760KV with cooler, $100.00 shipped , 5670 4Y 1000KV with cooler $120.00 shipped , both motors $200.00 shipped lower 48/ low use on them both have 8 MM bullets
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<5670 STILL FOR SALE $100.00 SHIPPED LOWER 48>>>>>>>>>>>>>>>>
    Apr 2011
    oh
    1,109
    new prices , 5660 $100.00 and 5670 $120.00 , or both for $200.00 shipped lower 48
    Apr 2011
    oh
    1,109
    weekly bump
    Nov 2014
    Sn
    274
    The 5660 is 12s and the 5670 10s ?
    Apr 2011
    oh
    1,109
    5660 10s or 12s and 5670 8s or 10s
    Apr 2011
    oh
    1,109
    new price 5660 $80 5670 $100 , good deal 2 good motors
    Nov 2014
    Sn
    274
    If you still have the 5660 I will take it shpiied to FL
    Apr 2011
    oh
    1,109
    yes i have the 5660 it , sending you PM
    Nov 2014
    Sn
    274
    Payment sent.
    Apr 2011
    oh
    1,109
    5660 sold , 5670 still forsale , Bill
    NH
    44
    Will the 5670 push a 50inch apache?
    Apr 2011
    oh
    1,109
    it would on 9s or 10s , Bill
    Jan 2016
    1,464
    Quote Originally Posted by maverick pro View Post
    Bill is correct on 9S or 10S. I have an Atomik ARC 58" cat using the same motor Bill has, TP 5670 4Y 1000kv with a FC 240A ESC and it ran in the low 50mph on 10S. On stock form I got it to run in the 44mph on 6S with a 120A esc after doing some tweaking. However, my ARC is not completely watertight as it has a top scoop which is covered with just a screen and at the back where I had two scoops, I modified that by removing the two scoops and putting louvers on them which furthermore provided another two areas where water could get in in case of a blowover. So I never had it on full throttle on 10S. So I imagine I could have pushed it to high 50mph or maybe hit 60mph? I since have removed the motor and plan to cover the scoops, the two louvers and make it watertight so I can make it a twin setup. But, yes the TP5670 is capable of pushing your 50" Apache and with a bigger and better ESC you can probably have it running in the 50- 60mph or maybe higher depending on the prop choice. Hope that helps your question.
    Also, for $100 it's a good price.
    NH
    44
    The apache with hardware and rudder servo is 10lbs no motor esc or batts.
    looking for 45-50mph with good run times. its a heavy boat as it used to be gas so the layup is solid.
    How many runs on that motor? Still have plenty of life left?
    Thank guys for the info.
    Jan 2016
    1,464
    The Atomik ARC specs says it's 13lbs (with two 3S 11.1V 30C 7500mAh LiPO batteries). .it's a fiberglass hull but pretty light for it's size. So I would say it's pretty close on weight wise with the Apache. Also, I forgot to mention I used 4 X 5S 5000mah batts which I'm sure added significant weight. I'm pretty sure with the TP 5670 with at least 240A esc, since that's what I'm gauging it on, and the right prop you could easily get it to 45-50mph. There are guys here with far greater experience than me and perhaps they could chime in to get you on the 45-50mph speed..
    Apr 2011
    oh
    1,109
    thanks guys for your imput and info , interesting your thoughts , BTW very little run time on this motor, i have another one in a sprint cat and i get 70 mph on that one on 10s, Bill
    NH
    44
    Quote Originally Posted by nmnorth View Post
    Hey bill...would you happen to have a mount for 5 inch rails for it?
    thanks again...
    NH
    44
    Thank you for all the info Bp. I'm still very green to electrics.
    thanks again...
    Apr 2011
    oh
    1,109
    Sorry, i don't have a mount , easy to get one though , Bill
    Apr 2011
    oh
    1,109
    5670 still for sale $100.00 shipped lower 48
    Aug 2008
    7,080
    I'll take the 5670 for $100. what size shaft, 8mm?
    "Look good doin' it"
    See the fleet
    Apr 2011
    oh
    1,109
    yes , 8mm shaft , sending you payment info by PM
    Aug 2008
    7,080
    $$ sent. Please send tracking when shipped.
    Thanks!
    See the fleet
    Apr 2011
    oh
    1,109
    got it jesse , will ship tomorrow, Bill
    Apr 2011
    oh
    1,109
    Jesse, PM'd you shipping info, Bill
    Apr 2011
    oh
    1,109
    All motors sold, Bill
    Aug 2008
    7,080
    Thanks Bill, will let you know when it's here.
    See the fleet
    Aug 2008
    7,080
    It is here and it is big!!
    Thanks!
    See the fleet
