Results 1 to 19 of 19
Thread: Zonda build
    May 2017
    14
    Default Zonda build
    New to RC boats, new to this forum, so diving in with a Zonda build.
    May 2017
    14
    Blank hull ordered from Hong Kong.
    Drive line mock-ups started
    Jul 2015
    701
    Question...is that motor mount going to fit in the sponson at the correct angle, or do you have to mod it?
    Jun 2015
    Wi
    734
    Are you setting this up as a twin?
    May 2017
    14
    It has slots in the sides so can be adjusted somewhat. But mod'ing it is also on the table.
    May 2017
    14
    Quote Originally Posted by Mxkid261 View Post
    Yes twin, other screw is in the picture on the balancer. First ever boat build, so hopefully will be fun building and learning.
    QL
    152
    Looks really nice. All the best with you build. I have a CF Zonda too i wish to rebuild when time allows
    May 2017
    14
    Quote Originally Posted by hughb View Post
    Thank you. Should be a fun build.
    Dec 2015
    La
    550
    Nice going. Good luck, there's a lot of good info on here.
    May 2017
    14
    Quote Originally Posted by Beaux View Post
    Thanks. Will probably be scanning for build info as it moves along.
    May 2017
    14
    RH driveline started. Need to ream out the stinger for the stuffing tube. A bit tight and not going to force it.
    Jul 2015
    701
    Before you go reaming, what diameter are the shafts and tubes?
    May 2017
    14
    Quote Originally Posted by Prodrvr View Post
    Stuffing tube fitted nicely in LH. RH had burrs so reamed them out and fits perfect now. (9/32 brass for 0.187 Teflon)
    Dec 2015
    La
    550
    Just checking if you got a left hand drive cable...
    May 2017
    14
    Yes a LH and RH. Does anyone have estimates of length change at full RPM
    Jul 2015
    701
    Quote Originally Posted by ade-rc View Post
    3/16" cable...leave a 3/16" gap between the end of the stinger and the back of the prop dog.
    May 2017
    14
    Thanks, Don't remember seeing gaps that big when researching boat builds. Was planning on maybe 0.040"-0.050" with a Teflon washer. Will need to dig deeper.
    4,119
    That's not enough. No real need for the washer if you run a proper gap. I also just use the diameter of the flex as a guide.
    May 2017
    14
    Thanks for the info. Will make sure I have enough adjustment in the drive lines to accommodate the gap.
