Results 1 to 2 of 2
Thread: 300 lite settings
    Jun 2011
    ct
    790
    Default 300 lite settings
    programming my 300 lite in the zelos cat. running TP 5670 840 kv on 10s2p 10,000 mah. what lvc is recommended? I am using a graupner pistol radio with telemetry. temperature and main pack voltage. where should I put the temperature probe on the esc?
    7,342
    I have been trying 3.5'ish for LVC but it has been a bit high so 3.3 should be good. I try not to run them down too far. (30-40%). But I just recently got Graphenes and it has changed how I run again. They don't seem to have an issue going down to 15%.
    As far as the temp probe I think on the aluminum that the water flows thru.
