Results 1 to 9 of 9
Thread: Hobby king Apparition II
    Mar 2017
    Ny
    72
    Default Hobby king Apparition II
    After buy the H.K. Genesis and liking it I bought
    a apparition ll. I just got it today and started to grease
    It up. Sausage fingers and this hull don't mix!!
    I figured if the genesis was a good boat this one should
    Be also both made by tfl.
    The paint looks good until you run your fingers over it
    And you can feel the over spray. A little compound on a rag and buff it smooth. No biggie
    While gripping the hull to polish the paint I hear a pop!!
    Oh boy it's the sticky to the touch glue the motor
    Mounts are glued in with coming loose!!
    The hull is thin enough that I popped the other mount
    Also. I need a good set of ball end drivers to work on this
    Boat.
    The battery,esc,servo tray is glued to the tunnel flat
    Still haven't found a spot where a zip tie will fit under it
    The stingers look well made and the two props
    Are brass and counter rotate. needs locknut
    I don't trust those bullet nuts. The rudder seems
    Small but I guess it will do the job..
    All in all I guess it will run or blow up
    Either way it will be fun!!!
    4,119
    Always thought it was a good looking boat. Hope it runs good once you sort out the build issues.
    Mar 2017
    Ny
    72
    Got around to glassing in the sponsons
    And set the motors. Just have to wait on esc's
    Mar 2017
    Ny
    72
    Update on the app ran it two weeks ago and it's
    A pretty slug... the twin set up was pulled out
    And Newboater sold me ( if it's the right motor)
    Two sss 3660 1620kv motors. There real tight in
    The sponsons so I'm thinking about a single motor
    Apparition. Now I need all the fun stuff to pull
    This off. I still have the swordfish 120 esc
    And the one 3660 motor.
    Any advice is welcome
    359
    Yes they are 3660 SSS motors, they should fit you might need to rotate the water jacket around to get the best use of the space. Then go with 120 or 150 amp ESC and go with 5s per side, and if that ain't enough go 6s. I'm pretty sure that boat would move pretty good with the two 3660 and then you don't have to be sealing up the holes that are already there for the twins. Come on Mark I can get my mitt inside the Princess.................
    Mar 2017
    Ny
    72
    Going single.
    Jul 2015
    701
    Nassau county cop next to LIE right?
    Mar 2017
    Ny
    72
    Yup. I'm on the service rd OSS
    Oct 2013
    la
    8,740
    Quote Originally Posted by Bigford View Post
    What advice would you like? About a single? I can advise you on that. I've built quite a few (Rivercat and apparition are the same boat made by tfl, just renamed by a company named Fightercat who used to sell the boat under the Rivercat name).
    They work really well in twin or single. I like the way a twin drives but there's not much room for anything so I usually build them as singles. Here's the last one I built
