Another weekend of fun at the lake. Then I lost the prop
Apparently the lock nut walked off and the prop went with it. This is getting to be an expensive hobby!!
Sorry I couldnt make it this am. With tomorrow being a bust weather wise Im taking care of a bunch of yard crap today. My bullet connectors will be in next week, and I just bought a soldering iron today at HD, so I will be able to set up 6S by next Sunday morning. I just attached one of those collar things on my flex shaft to prevent losing the prop and the shaft, might be something worth looking into for your application.
I'm still running the two part drive line
So my shaft can't fall out
Wait till you cook a few ESC's and waste a few lipo's Boats are known as money pits so why would the hobby be any different. Just finished taking the 35mm 4 blade Raboesch prop I bought for my Tug, and grinding it down to 29mm. Want the Tug to be a little faster then stock, but the 35mm 4 blade made it run too fast and way too nose high, looked ridiculous. Ground it down to 29mm and reshaped it so hopefully that should do the trick.
quick little video boat runs consistant 40.8mph
https://youtu.be/iYT1gVucW9Y
Good show. Now I'm really bummed out. Tried an Octura 447 prop and got just 27 mph, Graupner plastic 448 and got 26 mph. So, I lost a little from the Octura 445 at 28 mph. I have to rethink the whole setup. If I stay with 4 cells, I have other motors in the 2000 kv range to try. If I go to 6 cells, then I need to get a 40 mm motor of around 1600 kv.
I ran at Artist back in the late 80's with our club LIMBA we were running nitro back then the sunday morning scale guys have been there before us I live localy I have to pay $70 for a permit to run gas there but between the fisherman and the duck feeders to much hassle any way guys I sell props and revolectix batteries I have a few Aeromarine cat hull if you need any thing drop me a e mail
How fat from the lake are you? Should stop by
Sundays at 8am
Before abandoning the ship go back to the 640 prop and try that on 5 or 6s. Check speed and temps. Bigford (Mark) runs the 2075 motor in a cat with a 3 blade 38mm and gets 56 with esc temps of 120. The motor maybe okay in the boat on 6s just reduce the prop back to the 640 and see what speed and temps you get. Then we can take a more educated guess as to the right set-up.
My temps running theleopard 4074 1650kv and raider 150amp esc were 94* on the esc and 86 on the motor with the 645 prop. Oh and we also met you friend Doug (samek)
I will be running your 1914 prop on Sunday on my Impulse 31 to see if it puts me in the mid 50's like we discussed. I ran your 1814 with the same results as the 645 I did 52/53, hopefully this prop will get the job done. If you're not doing anything come on down most of the guys who were there way before us just run tug boats and some brushed motor electrics in the 15-20mph range, funny thing is they still have an occaisonal break down even at that speed.
I ran a 1914 on my impulse yesterday for 20s. Hit 17mph right before the cable snapped and lost the prop. Interested to see how you do with it.
No, cheap original Proboat cable. I think they're crimped, no soldered. Replacing with a wire drive, but still deciding on the replacement prop which is why I'm interested in Newboater's run.
For a big boat named princess she hauls ass
I am running two 3s packs SMC 7200mah that are over a pound each. I have them mounted left and right side of the motor
Its going to be an Electric conversion.
Need to find you one to race with
Or lose a prop
Ill be there. Just completed soldering up a few batteries with 6mm bullets so Ill try running 6s for the first time. Hopefully the boat stays right side up and my ESC doesnt melt down!!!
It looks like the ESC you received could actually be the one's pictured with heat shrink over them, well that, and different colored wire. Possible?
Twice the size of the one in the top pic.
Mark,
where did you get the ESC's from, also looks like the weekend might be a wash out with rain.
