Results 1 to 16 of 16
Thread: Blackjack dual rudder pickup upgrade
    Jul 2016
    199
    Default Blackjack dual rudder pickup upgrade
    Just finished my dual rudder water pickup upgrade. Installed an additional outlet on the other side of the boat so I have two separate lines for motor esc
    Wa
    5,905
    What is having dual rudders going to do for the BJ
    Billy Graham
    Jul 2016
    199
    Not duel rudders. A rudder with duel water pickups. It allows u to run two separate water lines one to cool the motor and one to cool the esc hopefully providing better cooling. On the stock setup with a single line water runs through the motor then continues on through the esc and out
    Jul 2016
    4,100
    That's the M41 rudder?
    AZ
    8,009
    ....On the stock setup with a single line water runs through the motor then continues on through the esc and out
    If yours was configured this way it was wrong. The water should always run through w ESC first, then the motor. Due to the short dwell time the water has in the ESC there is not a lot of heat removed by the water. Running the water stream to the motor next is more efficient than the other way around. If you want to run dual water lines that's fine, but don't expect a big difference in temps if ALL things remain the same. At least that's how it played out in my testing on a 10S boat.
    Jul 2016
    4,100
    That boat was previously mine. After dialing in the setup on 6S with a 440/3 prop, the motor temps got much warmer, while the ESC temps remained similar to the previous prop I had run with a higher timing setting. I plumbed the motor in before the ESC and the motor temps improved on the following runs, with no real change to the ESC.
    Jul 2016
    199
    It's the upgrade rudder OSE sells for the M41. Had to cut it down to match the length of the stocker then sandblast and paint
    Jul 2016
    199
    Ya u maybe right but this same setup on my spartan helped. Gonna be running 6s so I thought I'd give it a try. Plus it gave me a project to do. I can't leave anything alone lol
    Oct 2016
    pa
    476
    my motor hit 150 today on todays run . previously it was 135 but that was after like 2 minutes .this time was over 3 minutes until i tested . if motor temps dont improve i foresee another motor in my future .
    Jul 2016
    199
    Ran my Blackjack today. 1st run about 5 min 6s esc 115f. Motor 110f. Set it down and let it cool down while I ran my Spartan. 2nd run fresh packs did a complete run till I hit the lvc. 122f esc 120f motor max speed 59mph. I was running it pretty hard alternating between WFO runs downwind to medium speed back into the wind. It was about 65-70f out when I ran this morning
    ON
    2,908
    Quote Originally Posted by REDLINE1 View Post
    Doing this is not the best thing for your batteries.
    What voltage do you have your LVC set at?
    What % is left in your packs at this point?
    You should never run your packs below 20%, if you want them to last.
    Larry
    Jul 2016
    199
    Larry
    I usually don't run to the LVC which is set at 3.2v I run alarms on each battery set to 3.4v but the settings on them got screwed up and I ended up hitting the 3.2v setting on the esc. I wanted to do a full run to see what my temps were to see if my dual water cooling rudder was helping with the temps
    Oct 2021
    ok
    2
    Hey Redline1, I know this is an old thread, but how did the mod work out for you long term?
    Jul 2016
    199
    Quote Originally Posted by random rc guy View Post
    still runs great one of my favorite boats
    Oct 2021
    ok
    2
    Thanks man for the reply, did you notice better water pickup with the dual intake rudder?
  16. #16
    Jul 2016
    199
    Yes put an extra outlet so two lines one for the motor and one for the esc
