Results 1 to 6 of 6
Thread: I apologize if this is not the place for a suggestion.
    Nov 2016
    2
    Default I apologize if this is not the place for a suggestion.
    I had recently Overhauled my Gieco V3 - I upgrade to OSE heavy duty flex cable assembly, and CNC 7075 prop. I used the provided included (cable assembly locking nut and bullet nut)
    The torque after 5+ minutes of running, literally loosened and spun off both nuts ( YES I LOST BOTH MY NUTS! ) :)
    I might suggest that a nut with nylon is included instead to make assembly more secure.
    And yes i was sure everything was tight before running....
    AZ
    8,010
    I have no control over what Steve sells, but IME you should always use a true lock nut, like these:
    https://www.offshoreelectrics.com/pr...?prod=ose-8135
    Jam nuts cannot be relied upon to hold a spinning prop. They may work for awhile, but they will eventually fail.
    Jun 2015
    Wi
    734
    Quote Originally Posted by lonewolf0420 View Post
    I ALWAYS put a dab of locktite on the prop shaft threads no matter what kind of nut is on there. Usually just a lock nut is all I use. My buddy runs a bullet with a dab of locktite and that's it. Lost a $50 prop once, never again.
    ON
    9,400
    I lost a x455 Dsasbota prop using a nylon lock nut, never again. The lock tite will be my new norm with those aircraft lock nuts.
    Oct 2013
    la
    8,740
    I use loctite too but if you swap props as much as I do, you don't give it a chance to loosen up. Lol. I did lose a prop once using a set screw type bullet nut. I no longer use those.
    Nov 2016
    2
    Ouch!
