Results 1 to 5 of 5
Thread: charging 4 5s 5000mah revos.
    Jun 2011
    ct
    826
    Default charging 4 5s 5000mah revos.
    I have a question about power supplies. I will be charging 2 sets of 5s batteries at the river. 10s2p (4) 5s 5000 mah revos. buying a 1600 continuous watt generator. 2000 watts peak. i have (2) hp 47 amp 575 watt 12 volt power supplies. (2) revolectrix powerlab 6's. would it be better to hook up the power supplies for 24 volts and power the chargers off that, or run each charger off it's own 12 volt power supply. thanks
    Sep 2007
    NC
    2,778
    24V is preferred, but you run a little more risk daisy chaining power supplies. Like speed controllers trading off current for voltage is always easier on the electronics. I would just run each charger off it's own 12V supply.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Jun 2011
    ct
    826
    Default charging 10s2p
    thanks tyler
    Dec 2010
    NY
    3,115
    John I just bought the Revo power lab dual 8,,,awesome charger I got this 24 volt power supply for under $75 shipped,,, they can be ran in series http://www.ebay.com/itm/142323509073...%3AMEBIDX%3AIT
    Jun 2011
    ct
    826
    i charged (2) 5s 5000 from storage charge in 20 minutes with 12 volt ps. that was at 16 amps on cellpro 6. thats probably max charge rate, huh? batteries and charger, cool to touch.
