Results 1 to 9 of 9
Thread: Top Speed on 6s????
    Feb 2017
    ks
    4
    Default Top Speed on 6s????
    Ive had my Voracity for a few weeks now and I finally got some glass smooth water and did a top speed run. Im running 5400mah 75c X2...Im only getting 39.6mph! I tried a battery swap with the same results. Temps are good and the boat seems to be running great, but I expected closer to 50mph?!!?!?!? Thoughts ?
    4,100
    battery placement? drivedog gap? balanced and sharpened prop? prop size? strut position? trim tab position? A lot to be answered, a lot to be adjusted.
    Jul 2015
    701
    Quote Originally Posted by robertm235 View Post
    That seems to be a major misconception. For top speeds, you want a small chop on the surface, not glass flat. Glass flat presents more drag on the hull.
    Jun 2015
    Wi
    734
    Need more info. Is the boat running wet? Probably plowing through the water.
    6,183
    Don't laugh. I've done this multiple times. Make sure you didn't parallel two 3s packs instead of putting them in series.
    Noisy person
    8,009
    That seems a major misconception, I hear it all the time. Yet, most all the highest speed SAW records were set on pretty flat water. If your boat is faster on choppy water then it is set up too tight for smooth water.
    But what do I know, I've only set a couple dozen SAW records in both NAMBA and IMPBA....
    Jul 2015
    701
    Hmm, how about that.
    Jan 2013
    Ga
    1,358
    ESC is not set to max throttle position maybe?
    Oct 2013
    la
    8,740
    I've made my fastest passes on flat water. So I agree.
