Page 3 of 3 FirstFirst 123
Results 61 to 73 of 73
Thread: Big Boy Feigao 580L
  1. #61
    Mar 2008
    Au
    806
    I run the 6L in my 29" cat on 4s1p, top speed in race trim so far is 48mph, thats with a m440/3 prop.
    Heath
  2. #62
    WA
    13
    Smile
    Quote Originally Posted by Heath M View Post
    Heath
    Heath, Why would you run a large 580 motor in a small cat I would say an 10 XL or 8XL would be better in 4s
    Would you have a C of G to high with all that weight?
    Just wanting to set up a 34 inch cat with a single drive and keep the C of G low to keep it stable.
    Heath does it matter? or i am been to fussy?
  3. #63
    Mar 2008
    Au
    806
    Zane,
    The motor is perfect for it, look at the pic in my avatar that's it there. I have the COG set between 30 and 33 %. The single 4s pack set across the boat in front of the motor evenly distributing the weight. Come up to Lakeside this Sunday if your in the brisbane area and you'll see it run
    Heath
  4. #64
    WA
    13
    Wink
    Zane,
    Heath
    Heath I mean C of G up and down
  5. #65
    Mar 2008
    Au
    806
    If i understand you correctly, thats why i have the battery in front of the motor across ways to help get the nose down
  6. #66
    WA
    13
    Smile
    Heath, I mean High C of G or Low C of G Not bow to stern.
  7. #67
    Jul 2007
    or
    1,088
    I ran the 580L 6T on my XT460 Tunnel hull yesterday. The motor is an animal, far too much power for the 7.5 sized tunnel hull. Folded the bladed over on a heat treated octura 1450, huge amounts of torque.
    Setup:
    Lee Craft XT460 tunnel
    Hyperformance 7.5cc bullet drive
    4S2P 4500 30C elite cells
    CC Hydra 240
    580L 6T
    Prather S235
    Temps after 6 laps and a mill lap:
    Motor-115f
    ESC-cold
    Cells-120f
    6100 mah used.
    I think a 7T will be better on this boat. Unbelievable performance for the money. The 6T is going in a rigger next. The 6T and 7T are probably the ultimate budget P class competition motors. I certainly wouldn't feel like I was at a disadvantage running them against more expensive options. Upgraded bearings aren't a bad option.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
  8. #68
    Aug 2007
    3,031
    Brian, thanks for the update, these are very good news...
  9. #69
    ma
    8,693
    Quote Originally Posted by raptor347 View Post
    Setup:
    CC Hydra 240
    580L 6T
    Prather S235
    Motor-115f
    ESC-cold
    Cells-120f
    6100 mah used.
    Thanks for the info Brian!
    Steven Vaccaro
  10. #70
    WA
    8,335
    Yah... this thing was STUPID fast... WAY more power than the huge 34" hull could handle... I think this would be very interesting in a P-Mono...
    Darin E. Jordan - Renton, WA
  11. #71
    Jul 2007
    or
    1,088
    Here's pis of the boat and install. The hull is 33 7/8" long. It's 41" from the nose to the end of the cavitation plate. The 580L is a big motor and it looks small on this setup.
    I milled holes in both the endbells so that it would drain after the inevitable flips and flyoffs.
    I'm going to swap the 6T for a 7T and tune it to run 2 lap time trials. I can only imagine the carnage of a 6 boat heat of these things.
    NAMBA FE Chairman
  12. #72
    992
    Heath
    So what was the consensus on this? I ask because I am about to build a 29" sprint cat and thought for a moment about the 580L. It initially would seem that this motor is to big for a 30" hull but you, Heath, has been able to make this work. Any thoughts from anyone else? thx
  13. #73
    6,453
    I am considering this motor for my Triton build. Any thoughts? overkill? after quite a bit of researching I found this hull was designed to handle more power than most people put in it.
