Results 31 to 60 of 73
Thread: Big Boy Feigao 580L
  1. #31
    Wouldn't one of these work? http://www.offshoreelectrics.com/pro...?prod=gnd-4198
    Hmm.. My 31" Olympia Hydro may need a new power plant.
    JD
  2. #32
    2,917
    The 580 is listed at 1800 W
    1800 devided by 22.2V = 81A max
    The KB45 is listed at 3000W
    3000 devided by 22.2V = 135A max
    It would seem to my that the KB45 would be a better motor with more power.
    Also you can get a water jacket on it to keep it cool.
  3. #33
    WA
    8,335
    My first thought on this data is that the KB motor is listing it's Burst max W, and the Fiego is listing it's continuous W... I may be wrong...
    I also bet that the Fiego is a better quality motor than the KB.... I've heard the KB motors don't perform up to their rated specs, but that's just what I've heard... I've never tried one...
    Darin E. Jordan - Renton, WA
  4. #34
    1,711
    The KB45 is 1500 watts continuous with water cooling/ 2700 watts 30 second burst.
    So I am guessing the Feigao 580L is 1800 watts continuous with water cooling / 3000 watts 30 second burst.
    ReddyWatts fleet photo
  5. #35
    2,917
    This is taken from the offshore Website
    It clearly says 3000W
    KB45
    Features:
    Winding Options: 8 Turn to 11 Turn.
    KV Options: 1700, 1400, 1200, 1000
    Weight: 555g
    Shaft Size: 6mm
    Size: 77 Long x 45mm Diameter.
    Comes with 4mm connectors.
    Produces up to 3000 watts.
    Mounting hole spacing is 30 mm.
    Mounting Screws are 4mm size.
    Recommended Settings:
    Max rpm of 40,000
    Max watts 2,500
  6. #36
    2,917
    Quote Originally Posted by ReddyWatts View Post
    How can you say it is 1800 watts continuous with water cooling,
    When you can not put a water jacket on it with the screw heads on both ends.
  7. #37
    Jun 2008
    planet earth west coast usa
    392
    remove screws on one end...install water jacket..reinstall previously removed screws..done...
    Ghost
  8. #38
    2,917
    Quote Originally Posted by ghostofpf1 View Post
    Ghost
    That all sounds good, Have you done it yet??
    Are the screws put in with thread lock??
    Did you strip the screw heads trying to get them out??
    Did they stay tight after you put them back in??
    Big question is does the water jacket fit without leaks??
  9. #39
    1,711
    Geeeez.....never been threatened on here before about a private message.
    ---Quote (Originally by ReddyWatts)---
    You are correct. I did not mean to contradict your statement. That is just what I had personally recommended for KB motor from experience and was guessing at the 580L.
    ---End Quote---
    If this is your own opion then post it that way.
    Put this on the web site or I will.
  10. #40
    Jun 2007
    5,190
    Interesting questions...Answers?
    Douggie
  11. #41
    2,917
    ReadyWatts
    Why send me a PM saying that your numbers are your own personal opion.
    The numbers I posted are posted on the Offshore Web Site.
    You posted some numbers, but forgot to tell everone that they are your personal opion.
    You must remember that a lot of other people read this to try to find true Info.
    I respect Steven enough to believe that the info on his web site is true.
    My threat as you call it was to state that your numbers are only your personal
    opion.
  12. #42
    1,711
    Cause its best to keep this kind of chatter off the site.
  13. #43
    Mar 2008
    So
    1,006
    Agreed! Now back to the subject at the matter and keep the threats and distasteful comment in private or somewheres else.
    Boy that 580L looks some good!!
    I cant wait to hear some results.
  14. #44
    Jun 2008
    392
    Quote Originally Posted by Flying Scotsman View Post
    Douggie
    Sweet Buddha...It'a simple piece of machinery...why all the angst
    In the absolute worst case Screws can be removed even if locked into place via cyanoacrylates with a little heat...ruined threads can be retapped and screws replaced.
    You'd think I was promoting kitchen table brain surgery
    Ghost
  15. #45
    ma
    8,693
    First let me say that I would not have offered and marketed a motor for our boating community that would not accept some sort of water cooling.
    The below picture was not going to be posted but I thought since some have had some questions I would post it. The reason for not posting is that the jacket is rather tight, but will fit with patience. I hope to have something along the lines of Feigao XL jacket/ Neu jackets in a month or so.
    Steven Vaccaro
  16. #46
    Ga
    5,267
    Why BLUE?? LOL
    Keep up the good work Steven!!
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  17. #47
    ma
    8,693
    Also, screws are removed easily with a quality 1.5mm driver. End bells come right off and can use these bearings
    http://www.offshoreelectrics.com/pro...mr696c-yzz-nb2
    Steven Vaccaro
  18. #48
    2,917
    Steven
    Thank You for that report.
    It is intresting that they use the big 6mm bearings with the 5mm output shaft.
    I like the Octura Flex Hex 5mm couplers more then the set screw type (6mm).
  19. #49
    ma
    8,693
    Steven
    The shaft is 6mm with a optional 5mm output shaft.
    I opted for them this way. Because of the more coupler options.
    Steven Vaccaro
  20. #50
    Mar 2008
    So
    1,006
    Good call on that one!
    The cooling jacket you showed, is that a new jacket or the same KB45 jacket? Looks similar.
  21. #51
    ma
    8,693
    Thats a kb45 jacket. The OSE Feigao 580 L jacket will look similar to this.
    Steven Vaccaro
  22. #52
    2,917
    Now that looks good.
  23. #53
    on
    1,921
    larry-
    i will have you Ply wood.
    EYEKANDYGRAPHICS
    www.rclipos.com
  24. #54
    Wi
    190
    would like to know from the "sport" pros if this motor would be a good candidate for a twin 53 or 58 inch cat using one of these hulls:
    the gaser version run around 13,000 rpm using somewhere around a 65 to 70mm prop.
    how could this be set up?
    would be a twin drive LiPos
  25. #55
    2,917
    For a hull that size you would want to run 8 to 10S
    8S with a 850KV motor would be 25,000 RPM and smaller props.
  26. #56
    Jul 2007
    or
    1,088
    I got my 580 6L today. Good bearings and balance. The phase wires are roughly 10ga. It looks great on the outside.
    So I opened it up and it got better. The winding are evenly compressed with the coils nicely lined up (no wandering at all). Lots of copper in this motor.
    The rotor is well balanced with the magnets mounted on an 8mm shaft that is turned down to 6mm for the bearings and again for the 5mm output shaft. Some how I don't think we have to worry about the shaft whipping at high RPM.
    Now for some good weather to go testing. Oops, gotta build the boat first.
    P.S. The KB45 water jacket fits fine.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
  27. #57
    Aug 2007
    3,031
    Quote Originally Posted by raptor347 View Post
    i got my 580 6l today. Good bearings and balance. The phase wires are roughly 10ga. It looks great on the outside.
    So i opened it up and it got better. The winding are evenly compressed with the coils nicely lined up (no wandering at all). Lots of copper in this motor.
    The rotor is well balanced with the magnets mounted on an 8mm shaft that is turned down to 6mm for the bearings and again for the 5mm output shaft. Some how i don't think we have to worry about the shaft whipping at high rpm.
    P.s. The kb45 water jacket fits fine.
    sweeeeeet....
  28. #58
    ma
    8,693
    The bearings are still the lesser expensive Asian ones. Some are better then others. But in the end a good set of bearings will be a thing to consider.
    Steven Vaccaro
  29. #59
    Jan 2008
    IN
    796
    How many of these things sold? Does anyone have anything good or bad with experience yet? I would like to run one on 8S. It will be my first HV setup and in a 36" glass cat boat. Very light.
  30. #60
    1,711
    Any test results of the 580L???
