Results 1 to 23 of 23
Thread: Mini KEP's Rigger
    Default Mini KEP's Rigger
    I am about to start building a KEP'S mini rigger.
    It's similar to the jae mini for the most part.
    I currently offer these kits for sale and figure I should probably build one and have some fun with it!
    I will post some photos and stuff up along the way.
    Check out this link for more info.
    http://www.ne-stuff.net/2016/03/keps...eebie.html?m=1
    If your interested in purchasing a kit then shoot me a pm let's keep that stuff out of this thread.
    Here are some photos of the parts and comparison of the sponsons to 21 size and 45 size.
    You know, we could probably run these at the old casting pond. That would be a good place to play with some mini/micro FE stuff.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    No doubt perfect size boat for that pond!
    Can build them quick and cheap!
    These are a very nice mini, mmm...
    There is a guy with a Mini KEPs racing at my club, and built light it is competitive in the Mini Hydro class, especially so in the rough. He scaled it down from the T2 plans before the mini plan was released, so there may be some small differences to the plan, but the size and shape are very similar. It looks like the materials were different though as he used carved balsa for the sponsons and laminated balsa-1/64 ply for the tub to keep the weight down. I think he got his in at 480g, surprisingly close to the 465g of my molded kevlar boat. <500g RTR is a good weight for a Mini Hydro, the minimum is 450g but I don't think that is achievable while using the full 450mm allowed hull length. My old Zippkits JAE mini was an overbuilt pig that came in at 620g, and while I have had some success with it, it isn't competitive with good modern hulls built with the supplied materials, though the plan can still be if built light.
    Paul "tug Killer" Upton-Taylor, Cat lover.
    FastElectricBoats.co.uk
    Jeff,
    What are you supplying with the Mini Keps, and how much will it cost? By the way, I completely forgot about the windshield for the ML RSX310. I'll get the pattern to you soon.
    Regards,
    Bob
    Quote Originally Posted by bob horowitz View Post
    Jeff,
    Regards,
    Bob
    I will make a posting in the unique products section eventually with all the kits I offer but for now I will PM you.
    Thanks for all the info!
    Had my mini keps out today for the first run. It's a fast little rigger with nothing but potential. Too bad I broke the motor shaft and lost the prop but another is on the way. Video will come soon.
    Where do I find KEP' S rigger
    Sent from my SAMSUNG-SM-J120A using Tapatalk
    There are free plans for the Keps and the JAE on Ne-stuff.net
    Quote Originally Posted by teamgear1973 View Post
    Contact Monojeff, I believe he is making laser cut kits of most of the Kep's boats.
    Bob
    Ok thanks guys
    I may sell you mine if your interested.
    I'm interested in this kit
    Still available for sale?
  16. #16
    FYI, 18 months later the molded boats have improved to the point that the KEPS mini is no longer competitive in the Naviga Mini Hydro class.
  17. #17
    I just wanted to build a mini rigger to scream around a small pond in my area
  18. #18
    KEPs, or JAE will do you fine then, while not competitive any more, they are still good boats, and the build is a big part of the fun to many.
  19. #19
    Jan 2013
    Ga
    1,282
    What's a good mini now to compete?
  20. #20
    JAE rigger is also considered
  21. #21
    The Rasch Exe-05 is by far the best out of the box, with the ecomaster mini hydro modded for 1/2 width ride pads up there too. Most of the others can be competed against with a well built lightweight Keps or JAE, but will be several laps behind an Exe-05 at the end of a race.
  22. #22
    Oh I forgot about the Dr Psycho Little Headshot, that is right up there with the best too.
  23. #23
    I like wood riggers.
    So I'm assuming this kit not for sale no replies from original poster?
    I really like the looks of this keps rigger as well as rigged insanity and predator rigger in that order. I'm interested if anyone has or can perhaps laser cut these kits.
