Results 1 to 19 of 19
Thread: CNC vs. Beryllium
    Feb 2017
    4
    Default CNC vs. Beryllium
    Which is better or does each have its pros and cons?
    It looks like pricing is close unless the Beryllium is sharpened.
    4,119
    CNC is just that, aluminum machined by a mill so it can be used right out of the package, relatively sharp and balanced. They're usually inexpensive, at the cost of hardness and durability. Beryllium Copper props need to be sharpened and balanced by hand for optimal performance, but are harder and stronger. The dust during that work is dangerous to breathe. I choose to let a professional do the work for me.
    2,729
    They both vary from brand to brand.
    ABC and Octura use different alloys, but both look and feel more or less the same, I wouldn't like to say which is stronger. The no name Chinese BeCu props are much brighter almost like brass and are noticeably softer so I suspect there is a fair bit of tin in the alloy.
    CNC props are available in several materials Tenshock are the best of the Aluminium alloy CNC props and are made from 7075T6 which feels a bout the same as an Octura or ABC from the bag, but 7075T6 is already hardened whereas you can still heat treat BeCu to further hardness if you have the ability and equipment (or can pay someone that does). The magnalium use in TP props is a little harder than BeCu, but more brittle. Most of the other CNC aluminium alloy props are made from 6061T6 which is much cheaper and easier to machine but also MUCH softer than even the no name Chinese BeCu. Doctorprops make CNC props in stainless steel and cobalt steel, both of which are MUCH harder than BeCu.
    Octuras are horrible out of the box and need a lot of thinning and sharpening then balancing, ABC seem to be a little better, still needing sharpening and balancing but less thinning. All of the alloy CNC props I have seen have had acceptable balance out of the box, but all have been fairly blunt and needed sharpening and rebalancing after for optimal performance, the harder alloys can be thinned out a bit for the racing we do here too. Doctorprops CNC props come truly ready to run, and are much thinner and sharper than I could make a BeCu prop without it folding its blades on the first run.
    Generally the CNC blade shapes are better than BeCu, some are direct copies of Octura's X series, but most companies offer something with less blade area than most that are available in BeCu, so the average CNC prop has lower amp draw for the same diameter compared to BeCu. I normally buy X series and cut them back past M series (which tend to have thicker blades, so a cut X requires less work than an M) to suit me. The low area TP props are copies of the Graupner carbon props and have the least blade area and amp draw for the prop size.
    Not CNC or BeCu, but I should probably say that the Graupner carbon 2317/2317 series props are the most efficient props out there. The low area, very low lift blade shape works extremely well, and the blades are perfectly tapered from tip to root. They are so good that I know people that have made molds and cast them from alloy and stainless, and TP copied the shape for their CNC props. None give the same runtime as the originals though, the carbons can flex under load, and the most load is accelerating out of the hole, so under acceleration it has lower pitch reducing cavitation for better acceleration and lowering amp draw at the same time whilst at top speed there is less load on it and the pitch comes back so the top speed is the same (or higher if you can prop up), it is not something that is possible with metal as even if you could engineer the strength well enough to flex, fatigue would quickly kill the blades. On the down side they are pretty brittle and you only have to hit the smallest twig to lose a blade, and above about 45mm they are really not up to the torque of FE. Buying a bunch or carbon props and working up checking for temps and/or runtime is a great way to find what metal prop to put on your boat, but once you find the right carbon prop, pick a metal prop one size down, as it will draw more amps.
    I do my own BeCu props with hand tools, which takes me about 4 hours and it makes my hands ache. I hate doing props, but love the satisfaction of having done it. I do not put monetary value on my hobby time, if I did and charged it at minimum wage (and there is no way I would do props commercially for minimum wage) I would be much better off buying a Doctorprops CNC prop.
    Jun 2014
    1,516
    Great info there!
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
    4,119
    Wow, now that's an answer. Where do babies come from?
    2,729
    Storks.
    Feb 2017
    4
    Thanks, very educational and a good laugh.
    9,401
    Nice write up.
    There are some nice looking stainless props on Ebay out of Ukraine but, I don't trust them. Has anyone had experience with them?
    9,401
    It's Doctorprops...
    2,729
    That will be Doctorprops or Alex Prop. They are pricey and may take a while to get to you, but are fantastic props.
    9,401
    Do they have more sizes than what is listed?
    Jun 2009
    2,536
    I bought two props from DoctorProps. Stainless Steel. CNC. Absolutely stunning. I have an X642 and an X445.
    9,401
    Haven't had a chance to try it I guess?
    Jun 2009
    2,536
    I tried the 445 on my P Sport. It was considerably slower than my H5, but that was expected. I don't have any apples to apples comparisons yet.
    Jul 2017
    34
    CNC does not mean aluminum. It stand for computer numerical control and can be done on any metal.
    Its just the process style of manufacturing.
    BTW Beryllium copper is extremely toxic , polishing , sanding and filling of that should be done with a respirator and hand protection.
    Feb 2023
    122
    I'm a wee bit more learned.
    6,191
    Amen. Can you imagine? One prop.......$750. haha
    I tried selling boats for a hot minute years ago. It got frustrating quick. At least for me it did. I figured I was making a ton less than I could make pushing a broom somewhere. I quit doing work for others unless they were already friends or family. I get a huge kick out of building for people but not for money.
    Noisy person
    OH
    1,585
    May 2009
    AB
    483
    It's Doctorprops...
    I have a few props from Alex for my gas Blazer, beautiful work and they run great.
    Namba District 16
