Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 91 to 120 of 186
Thread: What did you do to your boat today?
  1. #91
    Jul 2015
    638
    10/4 on those rocks,well I wanted more speed from my Zonda so I lifted the struts 1-2 mm,was faster but then blew over,trying to get my fighter cat more stable,goes bonkers when I pin it ,I'm thinking the props are too aggressive ,learned the hard way to tape the hatch on a spartan or any boat ,just take a minute to tape it and save lots of trouble,my rescue boat is a small traxxas that has a 10' string with a piece of foam tied on the end ,works really well,learned about it on this forum,
  2. #92
    4,119
    Just for clarification, the traditional taping of the hatch method is pretty useless on the Spartan because of the gaps and countours. I'm proposing a full on moving box style wrap around the whole she-bang
  3. #93
    Jul 2015
    638
    There is a red 2" plastic tape used in construction,available at any hardware that works great ,that's what I started with ,now I use the 1" tape from OSE with good results ,I had the hatch pull off a few times when I got my first spartan ,
  4. #94
    May 2014
    636
    Took the new vac-u-tug to the lake today for a trial run, ESC wouldn't arm. Awesome. Put the Spartan in next, managed 46mph on the second pass (still painfully unstable and slower than it should be), then ripped the hatch off and killed my GPS. Put the last boat in the water, after I slipped on the rocks and dropped it. Cracked the hull. I need a beer.
    Wow, at least you got home safely. Hope you had a second beer.
    Ron - The Villages, FL
  5. #95
    Mar 2016
    103
    Bath tub test :)
  6. #96
    4,119
    Weather here today is miserable, so a bathtub test is about as closet as I might get to boating as well. Might glue up my rescue raft though...
  7. #97
    Mar 2016
    103
    Here as well :)
  8. #98
    Nov 2008
    Ql
    3,169
    Well a couple of weeks ago one of the Dynamite motors failed miserably in my cat so I just finished installing 2 x HET Typhoon 650-68 1500kv motors for today's racing.
    Totally untested, so I've no idea on the props but I'll start with a pair of 4214/3 for the first heat, & go from there.
    The boat.
    The engine bay.
    The motors.
  9. #99
    4,119
    Colder today than it was in February. Oh well, keep building...
  10. #100
    Jun 2014
    1,516
    NEVER SATISFIED RACING
    Fine Design 32 V-Hull 4082+6s
  11. #101
    4,119
    Tested out the vac-u-tug and as expected, slow as hell. Ran the new Infinity Offshore for the maiden. It ran really nice in stock trim despite the ESC cutting out. Can't believe how well it self rights without any throttle input. Put the Barbwire XL back on the stock motor and ran a battery through it to make sure all was good before listing it for sale. It did really well. It's all relative, even a day full of slow boats can be fun.
  12. #102
    Jun 2014
    1,516
    Few things over the past few days:
    - Wet sanded the JetChopper 30 hull with 600 grit
    - Built the Chopper a new carrying stand
    - Sharpened the M645 prop
    - Oiled all motor bearings
    - Polished all flex cables to 1500 grit
    - Cut 1/4" off the Chopper rudder
  13. #103
    4,119
    Coated some new SR6000T receivers in epoxy. No "waterproof reliakote" on any of them.
  14. #104
    4,119
    Last couple of weeks I've been reinforcing the seams on the inside of my Infinity Offshore. It was almost a joke how poorly the two halves were joined together from the factory. I used finishing resin and chopped carbon fiber. It should be good to go now. Just need to install the new motor and ESC.
    2017-05-07 18.18.52.jpg2017-05-07 18.19.28.jpg2017-05-14 09.05.25.jpg2017-05-19 19.18.51.jpg2017-05-19 19.20.07.jpg
  15. #105
    4,119
    Took the Impulse 31 out for its maiden after the winter hull repair. Made it 20s into the run when the flexcable broke right in front of the prop shaft and sent a razor sharp Dasboata prop to the bottom of the lake. I bought the boat with a stock flex cable and was too lazy to buy a wire drive or upgraded flex. Bit me in the ass. Placing an order with with Wohlt's next week.
    Sent the tug out with the rescue raft and that was an equal failure. The raft wouldn't let the tug get on plane, as a result, I couldn't steer at all. Roped that back to shore, ripped the raft off, and sent the tug back out with a ball and string in tow. Circled the Impulse a few times, snagged it, and dragged it back. This was the first time the rescue raft got wet, so it was not surprising I was going to need to tweak it.
    2017-05-27 11.45.43.jpg2017-05-27 13.23.48.jpg2017-05-27 13.23.54.jpg2017-05-27 13.23.58.jpg2017-05-27 16.51.50.jpg
  16. #106
    Apr 2017
    Ny
    143
    Soldered up my batterys and esc with 6mm bullets. My first 6s run will hopefully be this weekend in my otherwise stock Pro Marine MTR.
  17. #107
    Jul 2012
    SP
    975
    Sorry if it's not Fe but today tested a Jae 67 I built to a customer. Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
  18. #108
    Apr 2017
    QL
    1,038
    very nice rigger Gill, as usual.
  19. #109
    4,119
    Snuck out of work today a few hours early to get some work done before Sunday morning's run. I Sold my Blackjack to REDLINE1 last year and have missed it ever since. His is running so well on the new motor that I bought a Miss Geico to run with him. I shortened the motor wires, soldered on larger bullet connectors, cut the stuffing tube back, and installed a Wohlt wire drive along with an OSE upgraded strut. I need to drill out some of the cooling inlets/outlets, caulk the 90* elbows on the water jacket, and plumb new cooling lines. I plan on just copying my old setup which was good enough for 76mph in REDLINE's boat the first time out, and then tune form there depending on conditions at the lake.
    2017-09-22 15.02.00.jpg2017-09-22 15.02.16.jpg2017-09-22 15.46.57.jpg2017-09-22 19.53.24.jpg2017-09-22 19.50.41.jpg
  20. #110
    4,119
    The Geico ran good today, but I got everything squared away except for the ESC. It didn't dawn on me until the third set of batteries that the ESC was set for 3S and I was running 6S. Got it corrected, but by then, the water had gotten pretty rough and I wasn't able to hold it wide open for very long. Had fun and the boat came back in one piece.
  21. #111
    4,119
    The motor in my Geico was running fine last weekend on the first few runs as long as the boat was moving, temps were int he low 120's on pretty aggressive props. However, the motor would heat soak and the temps spiked quickly as soon as the boat slowed down or stopped. I had an ESC programming issue, so who knows what that was adding in terms of stress, but things will definitely better better after today's project.
    I scribed a rectangular patch on the bottom of the last ride pad and then drilled out the four corners with a small bit on my Dremel. I then switched to a small mill bit and opened up the entire hole. Filed it square with a hand file until the water pickup snapped into place. The leading edge sat a little proud of the bottom of the hull so I ran the pick-up across a file laid flat on the work bench until it was flush. Mocked it up in place one last time and JB Welded it into position.
    2017-09-30 14.15.04.jpg2017-09-30 14.29.14.jpg2017-09-30 14.45.02.jpg2017-09-30 14.45.11.jpg2017-09-30 14.45.35.jpg
  22. #112
    4,119
    I needed to add a second water outlet and knew I couldn't handle seeing two different kinds of hardware, so they had to match. I had a matching set, but the existing outlet was epoxied in place and wouldn't come out. Went hunting and found the same outlet on my Voracity. Pulled that one, drilled a new hole, and installed. Matching, nice. Hopefully the JB Weld is dry by tomorrow morning and I can test it out at the lake.
  23. #113
    Jul 2015
    701
    You've got some skills man! That is one clean installation!
  24. #114
    7,630
    Nice Ryan.
  25. #115
    4,119
    Thanks! JB Weld is dry, cooling hoses are in.
  26. #116
    9,402
    Ran 2 boats for the first time in 1.5 years. It was great!
  27. #117
    Jul 2015
    701
    Wow, that's a hell of a stretch!!
  28. #118
    Nov 2008
    Ql
    3,169
    That is so good to hear Ray.
  29. #119
    Dec 2015
    La
    550
    I swapped some batteries around from my Pirate to my DF 29. Got my Mean Machine 2 and two F1 boats ready to for Sat. morn. Fun Fun Fun.
  30. #120
    Nov 2008
    Ql
    3,169
    Finally got around to removing the motor with the broken shaft out of one of my Sports hydros so repairs to the hull can begin.
    She was speared through the belly by the sponson of another boat in a racing incident. The force snapped the motor shaft, mangled the flex cable, & bent the motor mount. Not to mention the gaping wound in the belly.
    You can still see the broken shaft in the coupler.
