I need to clear out some "cap space" to make room for a much bigger project, so I've decided to sell my very lightly used TFL Carbon Fiber Cheetah Twin.
Boat is the 2016 NAMBA P-Offshore Championship winning boat. I haven't even begun to fully wring out what it's capable off.
Comes complete as shown. All the graphics are vinyl and can be peeled off easily if you wish to paint. Hull is in perfect condition. In fact, everything is in perfect condition.
Setup to run a 4S 5000mAh pack on each side.
Equipped with the following:
Two TFL SSS 3674-2075KV 4-Pole Motors
Two Dynamite 130A Brushless Marine ESCs.
Spektrum S6030 Digital High-Torque Servo
OSE .187 Flexshafts.
TFL Struts, modified with Lead-Teflon bushings and to accept standard flex cables.
OSE Thru-Hull water pickups
OSE Heavy-Rudder system
MBP Easy Move Carbon Fiber 45mm x 240mm battery trays
1 Pair of ABC 1716-17-45(2) props
If you run Spectrum TXs, if you let me know which one, I will include the RX as well. I can supply either an MR200 or an SR210, depending on which TX you are running.
The parts alone total nearly $1,000 for this package.
Asking $800.00 shipped in USA. (Shipping is going to be approximately $55.00 for a package this size). Even going low-buck on the parts, you'd never duplicate this boat for that price!
Add a pair of 4S 5000mAh batteries and bind/setup to your TX and you're off winning races!
I can supply a set of almost new Turnigy 4S 5000 mAh Heavy-Duty packs for an additional $60.00 shipped.
