Results 1 to 5 of 5
Thread: Castle hydra ice 240 question
    Aug 2015
    VA
    435
    Default Castle hydra ice 240 question
    Anybody ran the power setting at medium. I have been running mine on low but was just curious. Been running timing at 0 or 5. Running Leopard 4092 1750kv on 6s with 2214-10-50 prop.
    7,630
    I run mine on full, what are expecting? Should jump out of the water stronger on full(if that is desired) meaning you have to go easy on the trigger.
    Aug 2015
    VA
    435
    Looking for 2 or 3 mph. It jumps out of the water pretty good right now. Didn't know if putting it on high would put to much stress on the esc being that they are getting hard to find. I am running Revolectrix 3s[x2] 5000 70c. I notice it said make sure you have good batteries when on high. If you been running yours on full and you think the Revolectrix are good enough I'll give it a shot.
    7,630
    Oh you'll be fine, just as always, don't run the batteries down too much. Watch the run time. Those 4092's can draw the amps
    Aug 2015
    VA
    435
    The amp draw can be right large sometimes. Thanks for the info.
