Hi guys ,I use the antenna less receivers on my trucks ,will they work on a non carbon fiber hull? So I don't have to mess with the tube ,
Maybe, depends on the radio and the range required.
Just try running with the antenna inside the hull and see if it meets your range needs
That works on a spartan and a genesis ,I just leave the wire inside ,I was thinking receivers may have advanced in the past year that an antenna wasn't needed ,less stuff sticking out ,
2.4Ghz needs a specific length antenna. If there's not a wire sticking out of the receiver, it's still inside the receiver case. Nothing magic there. I actually ran a spektrum SR410 without an antenna at all, and managed a solid 80-100' range before I figured out what was wrong.
Tactic radios don't use an external antennae.
Guys, pay attention - the OP's receiver has NO antenna!
