like it say before I buy new want to check here thanks Chris
Chris
I use a hand held tachometer with a small rubber cup on the front, put it on the motor shaft or prop shaft(without a prop)
Use a low voltage battery pack 2S or 4S
Then divide your result by the pack voltage.
It is very accurate.
Got pics of the setup Larry?
Billy Graham
Jim
I just tried this one for you.
This is my "P" Sport Hydro, Neu 1515 2200KV
I hooked the boat up on a fully charged 2S 70C - 5000map Pack 8.4 Volts
Tachometer reads 18,500 RPM
Divide that by 8.4 = 2202 KV
ReddyWatts fleet photo
thank you guys !!!!
Chris
This is what I use... https://hobbyking.com/en_us/hobbykin...bl-motors.html
Instructions are kinda goofy, but once you get past that, it's smooth sailing.
There's other source's beside's HK
