finally able to post some pics gutted the hull started painting i want to go brushless, would blackjack motor and esc be better than sv 27 motor and esc ? what hardware should i use rudder turn fin any suggestions would be great
If you are wanting to go with a single motor, it will have to be a LOT bigger than that.
Try this for hardware:
http://www.offshoreelectrics.com/pro...prod=sol-hydro
What kind of speeds are you expecting?
The first thin gI would suggst doing it cutting out the ABS inner hull (if there if one) and coating the inside and transom with glass.
the rebuild status of the hurricane is on hold, since i already have an sv27 and am in the process of building an mm hull, i will need a rescue vessal and this will be it. new paint and same running system should work fine, you can always push your baots to another level when you know if it flips or blows over you can go get it and bring it back
hopefull these two wont need many rescues
paint done, have some pics of attachment i plan to use as rescue device any suggestions welcome
[I
MG]http://i476.photobucket.com/albums/rr127/sewerpit/pics065.jpg[/IMG]
Umm....
You might want to edit that one.
edit what ?
Pics don't show.
sorry you cant see them but they are there
can't see em on my puter either! Says "this image or video has been moved or deleted" Photo bucket
We did it with a Bang!
Cats Are Where It's At!
Pics don't work!!!!
MMGMMarine
RobertsonRacing
how bout now
http://s476.photobucket.com/albums/r...werpit/rescue/ hope this works
