im selling some extra servos that i had as spares . all have little to no use on them see the pics . any questions please ask !! ALL SOLD !!!!
#1 savox 1210 sg waterproof sold ...like new with aluminum servo horn !!!
The SW1210SG is the premier waterproof digital servo in the Savox Lineup. This coreless servo boasts 277.7 oz-in of torque and a speed of .15 at 6.0V. It combines leading edge technology with super high 12-bit (4096) resolution and steel gears for one versatile and waterproof servo! This is a great upgrade if your looking to drive your RC vehicle in any condition...rain, sleet, or snow.
Features:
Combines leading edge technology with super high 12 bit (4096) resolution and steel gears.
Waterproof.
Coreless motor provides high speed, incredible efficiency, and low power consumption.
Extremely strong steel gears ensure long-life and durability.
The aluminum case design not only looks good but also allows for cooler and smoother operating temps.
Ideal for RC cars, trucks, buggies, and boats.
Dimensions(mm): 40.6x20.7x42.0
Weight(g): 71
Speed(@4.8V sec/60): .18
Torque(@4.8V oz-in): 222.2
Speed(@6.0V sec/60): .15
Torque(@6.0V oz-in): 277.7
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
IP Rating: 67
Frequency: 250-333hz
Pulse Width Frequency: 1520
#2 savoxsc 158 tg black edition SOLD ... like new with aluminum servo horn !!
Savox's SC-1258TG Black Edition Standard Digital "High Speed" Titanium Gear Servo features a sleek black aluminum center case with laser etched details, as well as a shorter 200mm long heavy duty wire. The SC-1258TG is a great choice for 600 to 700 class heli cyclic applications, as well as 1/10 electric off road steering.
Features:
Black aluminum center case.
Shorter 200mm black shielded lead wire.
Combines leading edge technology with super high 12 bit (4096) resolution and titanium gears.
Super light-weight.
Titanium gears ensure long life and durability.
The aluminum case design not only looks good but also allows for cooler operating temps.
Our servos are totally green – from materials to production, these servos are environmentally friendly.
Ideal for 600 to 700 class heli cyclic or 1/10 electric off road
*NOTE: Certain combinations of receiver and ESC have been found to cause "Brown Out" issues when combined with Savox servos. An external BEC, or BEC stabilizing receiver capacitor may be needed for efficient, glitch free operation in low voltage electric applications.
Specifications:
Dimensions: 40.3x20.2x37.2mm
Weight: 52.4g
Speed:
@4.8V: .10 sec/60
@6.0V: .08 sec/60
Torque:
@4.8V: 133.3 oz-in
@6.0V: 166.6 oz-in
Gear: Titanium & Aluminum
Bearing: 2BB
Case: Aluminum
Output Shaft: 25 Tooth Spline
#3 hitec 7955tg SOLD
Hitec's best servo just got better. Based on the powerhouse HS-5955TG servo the HS-7955TG has the added benefit of our G2 second generation programmable digital circuit. This new circuit has twice the resolution of our original circuit while adding programmable overload protection. The HS-7955TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 333oz./in. of torque at 6.0 volts, all this power is harnessed by incorporating the industries first Titanium gears for incredible wear resistance and two strong hardened steel gear pins and axial brass bushing in the servo case.
Specifications:
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed: 0.19 / 0.15 sec @ 60 deg.
Torque: 250 / 333 oz.in (4.8v/6v) 18 / 24 kg.cm
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 2.29oz 65.00g
