Results 1 to 25 of 25
Thread: spektrum dx4s
    Jun 2012
    ny
    1,135
    Default spektrum dx4s
    I got this TX and a couple mr200 rxs were just working fine a couple days ago was trying to bind them agian because they would not work. I put bind plug in did the procedure like I normally do it binded ok but when I removed bind plug and hooked battery to RX and nothing. any ideas out there? will a faulty speed control mess up a RX ?
    WA
    8,335
    That TX is not designed for use with the MR200 or MR3000 RXs (DSM-Marine).
    It requires a DSM2 or DSMR RX, like the new SR210, SR310, SR410, etc.
    http://www.spektrumrc.com/Products/D...rodId=SPM4010W
    http://www.spektrumrc.com/Surface/marineReceivers.aspx
    Darin E. Jordan - Renton, WA
    Jun 2012
    ny
    1,135
    I have used these in boats all last summer with this tx
    WA
    8,335
    How old is the TX and when it the last time you updated it??
    WA
    8,335
    Here is what I can tell you about these radio systems:
    1) The TX and RX generally need to be the same generation of protocol: DSM2, DSMR, DSM-Marine, etc. In this case, the TX is NOT DSM-Marine Compatible.
    2) The EARLY runs of the DX4S and DX4R were released with support for the DSM-Marine RXs. In a later update, and later releases, this was removed.
    3) IF you had an early TX that was compatible, and you did a Spektrum Raceware update from www.spektrumrc.com, then the update will have removed the DSM-Marine support.
    4) RX Binding and connection after it's bound can be affected by weak RX batteries or low BEC voltage.
    5) RX Connection can be affected by having the TX too close to the RX. If you move the TX away and make sure the antennas has Line-of-sight with each other, it will generally bind or connect.
    Hope something in 1-5 helps. :)
    Jun 2012
    ny
    1,135
    Great info here Darin, it is a few years old and I haven't changed anything thanks very much for your help, geno
    8,009
    Cool
    #5. I learned that the hard way some years ago. Later when fellow club members couldn't bind their transmitters, I told them to take two steps back. Worked every time. Don't know if that is the OP's problem, but it is worth a try.
    Jun 2012
    ny
    1,135
    I tried everything one other one I have binder just fine, guess it's time for the garbage lol
    Dec 2015
    La
    550
    Just got my dx4c dsmr radio . Not real happy . I can get only about 50 yds. of range. Whats up?
    4,096
    Quote Originally Posted by Beaux View Post
    What kind of receiver are you using? Did that same receiver work with your previous transmitter? Fresh batteries? We need more information to help you.
    7,629
    And what is it in? If any sort of CF hull and the antenna is not clear of the hull you won't have any range.
    Dec 2015
    La
    550
    Thanks for asking. It's a mean machine 2, a tp 4070 , a sf 300 lite on 6s. Two freshly charged 3s . No carbon fiber the ant. is approx. 2 inch exposed. 5.7 volts at the radio. Four brand new freshly charged aa's.
    4,096
    receiver? Is that new or used? Was it previously paired with your last radio?
    Dec 2015
    La
    550
    Both of these are brand new out of the box. I have a sf310 in my pirate same issue.
    4,096
    Does the receiver antenna have a ~1" section of clear coating at the end of the antenna, which is otherwise solid gray?
    Dec 2015
    La
    550
    Yes,that plus 1 inch of the gray is exposed.
    4,096
    I suppose you should call Spektrum tech support next. I've got nothing left for you aside from trying a BEC. My past range issues were caused by broken antenna's (clear, unshielded portion at the end) or weak batteries.
    Dec 2015
    La
    550
    I'm already running a bec. Thanks for trying. I guess tech support is next, again thanks.
    Dec 2015
    La
    550
    Up date on the DX4C. We were going to small lake , they quit selling day passes, so we went to a friend's camp. There we have about 100 yds across and a good 1/2 mile either way.
    So I eased my MM 2 out and tiptoed along the rivers edge. It went for at least 200 yds. and never missed a beat. So I'm guessing the lake had some type of interference.
    The DX4C worked great.
    7,629
    Mmm, this is not the first strange interference on certain lakes. Perhaps something to do with those planet grid lines? J/K. Well glad that worked but crappy about the other lake if it is your local spot.
    Have you(or anyone else) tried another radio at that lake ?
    Dec 2015
    La
    550
    No , I tried a flysky was my first radio, and it messed up at the same spot. So I thought hmm, junk radio. Well my new DX4C did the same thing.
    Having to go to the river was a blessing . Got a nice deck and a fan in the summer. The other place was getting to small for the speed we were running.
    8,009
    Not impossible and I’ve seen it happen (with cheap 2.4 gig radios), but still odd. How is cell phone coverage at the pond? Near an airport?
    Dec 2015
    La
    550
    Never tried my phone, about 15 miles from a military type airport.
    Oct 2013
    la
    8,740
    There's a pond I used to frequent and it had a dead spot. Never failed, I went into that area, boat stopped. There's another area in my big lake I run it. I avoid it, works fine. Heck you can see in some of my videos where it cuts out.
    Jul 2018
    241
    Mine just pooped, went with the 5. my DX3C still works and my 4 was used a lot less. electronics, must be a Ghost in The Shell.
