Page 4 of 15 FirstFirst ... 2345614 ... LastLast
Results 91 to 120 of 425
Thread: The Black Pearl P Sport Hydro 2017
  1. #91
    Jun 2009
    2,539
    Yours is a V5.7, Ray. Same as the boats in post #1.
  2. #92
    9,402
    M spec is the future. LSH is the past. haha
    Did I miss a thread? I'm lost.
  3. #93
    6,192
    https://forums.offshoreelectrics.com/...pplement-rules
    It's experimental in truth Ray. We're not looking to fix P limited. Limited was NAMBA so I couldn't possible care less if that ever gets fixed.
    This is something new. We like to think of it as the next generation of spec racing. Idea is that you get to choose......or don't choose....... The equipment we've used for years in the old limited classes works up against this new spec. Proved that in AZ. Ray was cleaning up. Ty's limited offshore was right in there with the old tech too. I ran a TP. Ty had a Dynamite and we finished a 1/4 lap apart I think. So you don't need to upgrade (side grade?) unless you just want to.
    Noisy person
  4. #94
    9,402
    ...and found.
    Thanks for the details. My yellow cans are showing signs of impending death so I invested in some blue cans cause they were a darn good deal.
    I look inside the Dynamite and see a crap load of copper, not so much in the yellow cans... I sold my one TP motor long ago and that was a mistake. Oh well... blue it is for me for now.
    I find it a PITA that a spec motor costs almost as much a an open motor. That's silly but a reality none the less.
  5. #95
    6,192
    That's what we're checking on Ray. I just don't believe that paying 100's for a motor is going to net a reward in this class with a size limit. There are some really good motors for cheap now. Those blue can Proboat motors are the real deal.
    Noisy person
  6. #96
    Jun 2009
    2,539
    I cut the pcs for the new nose pc. It came together nicely. The previous nose weighed in at 5.6oz, even with the relief holes. The new one only weighs 1.5oz!!!
  7. #97
    Jun 2009
    2,539
    The top and bottom sheeting fits like a glove. Very happy with how this came out. I sanded the bottom face edges at 45deg to compensate for glue fillets underneath, and to allow more surface area for glue to adhere.
  8. #98
    2,913
    Pete
    I see you found some 1" 1/2 round.
  9. #99
    9,402
    Can this mod be added to a 5.7 to make the build easier?
  10. #100
    Jun 2009
    2,539
    Larry, I never found 1" half round. I ended up cutting 1" dowel in half on the band saw. Not easy. You can't twist it.
    Ray, Yes. I can cut you some nose pcs next time I'm out there if you want. It will definitely save you time.
  11. #101
    2,913
    How about two pieces of 1/2" Quarter round??
  12. #102
    Jun 2008
    GA
    2,318
    Would 1" foam be lighter ? Easy to sand to shape. You could skin it with stiff fiberglass or thin plywood.
  13. #103
    6,192
    Great idea Larry. You could even trim out some of it before you joint the two halves. Even more weight savings.
    Noisy person
  14. #104
    6,192
    I fabricated the nose of an 8255 Oberto from two part foam. Lots of easy sanding. Then glassed it. Light and strong as nails.
    Noisy person
  15. #105
    9,402
    Quote Originally Posted by Shooter View Post
    That would be VERY helpful, thanks!
    I'll let you know another day. Not in a big rush.
  16. #106
    Jun 2009
    2,539
    Light version in process! Mine won't be nearly as light as Terry's.
  17. #107
    9,402
    Wow, a 34" hull in specky class. Things are changing...
  18. #108
    Jun 2008
    GA
    2,318
    You can get creative and make a lot of parts (sponsons, nose piece, etc) from foam. Cutting foam with hot wire or sanding to shape, then coating with fiberglass. Spray a light mist coat of 3M spray adhesive to shaped foam. then lay down fiberglass cloth and epoxy. Lots of videos on YouTube.com that show how. There are lots of old RC Airplane tricks.
  19. #109
    Jun 2008
    GA
    2,318
    What? You are finally making a longer more stable version. You will see that it will turn just as good as the shorter version. And be more stable down the straits without blow over. Cool
    Unleaded...........
    whiplash 424.jpg[
  20. #110
    Jun 2009
    2,539
    It is still 33.5" long. I do plan on a smaller (lsh size) and larger (Q size), but not immediately. I understand your comment regarding a longer hull though, similar to a dragster or funny car keeping its front wheels on the ground. I see you have an extended strut. That's a good idea. I took a different approach with this hull. It has tapered air bleeds that keep the pressure underneath to a minimum. I haven't heard of anyone blowing these over, even at speeds in excess of 65mph.
  21. #111
    6,192
    It's already the most stable P sport I've ever driven.
    This spec boat I'm doing is an experiment to see if a big boat can hang with the stealths. I'm pretty confident.
    Noisy person
  22. #112
    Apr 2015
    Mi
    53
    Another secret project????
    I'll have to pull Ty aside and ask him the details!!!!!
  23. #113
    2,913
    Pete
    I sent you a PM
  24. #114
    Jun 2009
    2,539
    Quote Originally Posted by macomb View Post
    He'll talk for cheeseburgers (no pickle,I think)!!
  25. #115
    6,192
    Hell, he'll probably tell you prop too for a slurpee.
    Noisy person
  26. #116
    Fl
    90
    Here is mine... she aint black but she has some pearl.
    still gotta add motor and esc...
  27. #117
    Fl
    90
    last one.
  28. #118
    Jun 2009
    2,539
    I LIKE!!!! Beautiful!!!
    I see you went with the UL-1 canopy and divided the back into two openings. Nice!
  29. #119
    9,402
    It is very nice. Thank you for sharing pictures. I like that you left most of the bottom unpainted wood.
    Did you get the Speed Master stuff anodized or did you buy it that way? Turn fin mount at first I thought it was from an RC car part then I saw the back.
  30. #120
    Fl
    90
    its custom anodized....the turn fin mount is accu tech with a graupner sailboat turnbuckle added to alu mounts in the hull.
