Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 361 to 390 of 425
Thread: The Black Pearl P Sport Hydro 2017
  1. #361
    Aug 2018
    fl
    25
    Do you guys put finishing resin on the inside of the top skin before installing it on the hull
  2. #362
    6,191
    Not finishing resin but yes. Finishing resin has wax in it. My understanding
    Noisy person
  3. #363
    9,401
    I usually coat it when I go to glue it down.
    Wait for others to chime in.
    If it's for full P power or more, I do one coat, wait about 1/2 hour and add a bit more then start taping/clamping.
    I use slow set epoxy, MAS or West Systems, etc.
    What glue?
  4. #364
    Aug 2018
    fl
    25
    Awesome guys thanks for the quick response I have West 105 206 I’ll Apply underneath thank you
  5. #365
    Jun 2009
    2,536
    Congrats Ty!!!! New IMPBA World Record!!!
    OK. Getting a lot of inquiries. Going to make a spec boat this winter. Same concept. Built in motor mount.
  6. #366
    6,191
    That reminds me Pete. For P we had to add a tail ring. For spec should be no biggy.
    Noisy person
  7. #367
    Jun 2009
    2,536
    Been working on the spec boat with Terry. Basically just copied the sponson mods on Ty's boat. You cant argue with success!
  8. #368
    6,191
    Awe mannnnnn.....I thought it was a secret.
    Noisy person
  9. #369
    Jun 2009
    2,536
    I know I know.....but it was too cool not to brag about it!!!!
  10. #370
    Jan 2009
    AL
    143
    was hoping for this..
    JOHN A. GROSS
    MILLBROOK, AL
    Crickety Crack Racing Team
  11. #371
    May 2017
    OK
    1,464
    Quote Originally Posted by Shooter View Post
    SolidWorks? Nice!
  12. #372
    6,191
    Not solid works. Much more elaborate actually. Not sure Pete can share that information.
    Pete, I'm not sure how much you can open up the holes in it before it gets flimsy but yes please.
    Noisy person
  13. #373
    Jun 2009
    2,536
    I use Solid works as well. I actually like it better. I just opened up the holes in the front. I plan to cut the first frames Wednesday.
  14. #374
    Sep 2018
    IN
    22
    Lookin forward to see how this works out!! I bet it will test out great!!
    Good luck!!
    brian
  15. #375
    3,117
    The Pearl is a solid design. My hull is one of the originals (built by Pete) that was disbanded because it “didn’t” work. Insert Mike and his sponson mods makes for a pretty quick boat too!
    Uploading to YouTube destroys the video quality. I am probably doing something wrong...
    https://youtu.be/xw-HYFgPjkY
  16. #376
    Sep 2018
    IN
    22
    Yep! I'm planning on building one this winter. I think it will be a great runner! probable set it up to run limited. It'll be my first wood build for my first race season!! I'm excited!!!
  17. #377
    Apr 2017
    OR
    156
    So by the looks of it the air bleed channel is widened and the sponsons has no step? Is that right?
  18. #378
    2,729
    I don't know what resolution you recorded it as Mike, but it is only uploaded to youtube as 480p, and shot vertically so only about 300 pixels wide, shooting horisontally helps quality as does uploading as higher resolutions.
    You can upload it with a even higher resolution than you actually shot, so if you record in 1080p you can upload it as a 4k video, it will still only be 1080p, but the 4k upload allows more bandwidth so it will compress the 1080p footage less and be better quality than if you just upload it as 1080.
  19. #379
    Jun 2009
    2,536
    That boat has a lot of history and its only 4yrs old. Jimmy had it for awhile, then traded it back to me for a later version! And.....it's SN001!!! So......let's see what you did to it Mike!!!!! Congrats on the record by the way.
    You got it. No step on the sponsons and bleeding more air. Those photos in post #367 are already obsolete. I cut a kit and it just didn't look right. The tunnel was way too narrow. I widened the tunnel but kept the same transom width. Looks much better now. Just about ready to cut it.
    I had no idea you could upload at higher res than it was shot. Reduces compression. Good to know!!
  20. #380
    Jun 2009
    2,536
    OK, so here is the first spec boat. It is 31" long. Nothing glued, just fitted together. It was designed to fit the UL-1 hatch and nose with a piece of 3/4" round stock glued to the front. The airfoil is pretty aggressive on the leading edge.
  21. #381
    Jun 2009
    2,536
    The bottom is far from traditional. A lot of air bleeding.
  22. #382
    Jun 2009
    2,536
    It's not the roomiest thing under the hood, but I guess it wasn't designed to be a luxury vehicle! It's the F1 class of FE!!
    I did manage to pack (2) 4S graphene 4000's, which are very long.
  23. #383
    Jun 2009
    2,536
    One more pic with the UL-1 cowl...
  24. #384
    May 2017
    QC
    16
    wow, nice design
  25. #385
    Jun 2008
    GA
    2,318
    I remember my mother watched Jack Lalanne on UHF channel 8.
  26. #386
    6,191
    I'm not sharing my plans this time Pete. muhahahahaha
    Noisy person
  27. #387
    Jun 2009
    2,536
    what? Jack Lalanne??? and WHAAAAAAAAAAAT??? No sharing!!!!???
    Been a few weeks. Not good ones. I'm still swamped with other priorities. I have (2) of the LSH kits cut.
  28. #388
    6,191
    Pete, you coming to B's tomorrow?
    Noisy person
  29. #389
    May 2018
    344
    Quote Originally Posted by bikepilot View Post
    Just found this and am planning the same!
  30. #390
    2,912
    Any one interested in a new cowl for there boat?
    OK - made my first pull from this new mould.
    It turned out very good.
    This mould was made to fit the 20/40 Wiplash
    I cut the cowl to fit in the Black Pearl - It fits perfectly (curvature on the front fits), There is enough room on the surface's of the cowl, to move the bubble forward 2" or to the rear 1 1/4" from where it is in the pictures.
    I will start making some of these next week, MP me if interested.
