Page 10 of 15 FirstFirst ... 89101112 ... LastLast
Results 271 to 300 of 425
Thread: The Black Pearl P Sport Hydro 2017
  1. #271
    6,192
    Oh, Boat does not like big prop/lower kv setup.... It will start to porpoise if I hit any rough water. Little prop/high kv and the boat just hops up, flies level, then sets back down.
    The last Pearl I built didn't like the big props either. It was happier with the 1515 and a smaller prop. My old heavy whip liked a 447/3. Go figure. This next Pearl that is on the bench will be a tank so all bets are off on the setup. Might go back to the 1950 and try fat props again.
    Noisy person
  2. #272
    May 2017
    OK
    1,464
    For me, you’re right at the best part of RC boating... The wondering, the figuring, the building, the anticipation of the first run. Is the weight right, did I hit the turn fin adjust right out of the box! I really enjoy that part!
    Got a crazy idea I’m working on. (YeH, even more out-of-the-box than usual, lol!) I’m going to get another Vortex 34, because there’s so much bloody room in there, and set up a dual motor, dual prop setup. Been kicking around a couple of 2860’s with a center rudder and running a full dual motor mixer on it. I know no class for it, but just have to try it out! I want to try spinning the port side prop CW and the starboard side CCW. I’m wondering if it will cancel out most of the prop torque. Would turn the shafts pretty fast 35,000rpm and use small props, like 42-43mm.
  3. #273
    Jan 2014
    Md
    323
    Antonio
    The hull that runs 70mph is one of the old 5.7 kits
    This build and hull is a lot heaver then the new light weight kits.
    It also has some of my own mods built in.
    It is a full "P" setup
    NEU 1515 - 1Y - 2200KV
    Two 4S - 5000's 65-130C
    Castle Hydra 240amp
    Timing set to 15 Degrees
    ABC - 1815 -17 -45
    Build thread:
    https://forums.offshoreelectrics.com...10-Black-pearl
    Pictures
    https://forums.offshoreelectrics.com...p?albumid=1364
    I have since changed the turn fin, to make the hull more steady and run true without pulling to the right.
    Also had to replace my drive tube, due to a dent in it that I did not notice, - lost two shafts at the last race.
    Thanks Larry. I'll have to grad one of them props.
  4. #274
    Jan 2014
    Md
    323
    2310 is pretty hot. Which motor is that? 4070? It could work with a small prop. The 1515 runs warm too at 2200kv.
    For me, I prefer a few less kv with more blade in the water but results vary depending on which boat you're running. Some boats don't like a big blade. The Pearls do pretty well on 45mm props. A 45mm on a TP2310 will likely come in hot on the oval. Zip zip playing around it will work fine though.
    Your right spot on with tha one T. I try it and the 4050 2310kv is a hot setup on a 45mm.
  5. #275
    Jun 2009
    2,538
    I haven’t even tried turning full throttle, just feels like a suicide mission, lol.
    Hey Craig, what fin are you running? We usually keep the throttle pegged the whole race, even on the small radius turns on the practice pond. Keeping speed in the turns is a challenge. Best sport boat I've seen is Mike Ball's PT spec boat. It used to literally whip itself around the turns like a rigger with very little speed loss. We are getting closer to that with the recent changes (packaging most of the weight directly on the CG), but it's still a challenge with full P power.
  6. #276
    May 2017
    OK
    1,464
    Hey Pete, I’ve had 3 fins on the boat. First, a UL-1 fin with a side brace. That still deflected badly causing understeer at the apex. I got rid of that and put on a Speedmaster bent fin for a 1/8 scale boat. I cut the fin down to proper size for my 34” boat, it worked very well. It turns very well, just never got the nerve to turn full speed. Note, I run the rudder on the left. Then Oscar Love gave me a curved fin, again made for a 48” boat. Cut it down and it just tagged the right side down too hard. Even turning the fin out CCW didn’t get rid of the problem completely. I went back to the bent fin, shown below. I’ve never hooked or flipped the boat, so I guess I just need to turn it one day and see what happens. Pic below on the current fin...
  7. #277
    May 2017
    OK
    1,464
    I have a course set up that’s pretty close to 1/6 mile. Should I just prop down until I feel secure about full throttle turns, then try working it back up?
  8. #278
    Jun 2009
    2,538
    Oh Geesh....I'm sorry....I thought you had one of my boats. What boat is that? Sounds like you've tried quite a few things. I've done the same. Straight fins, angled fins, you name it. I always end up going back to a curved fin, thin as possible.
  9. #279
    May 2017
    OK
    1,464
    I’ve got a DF Vortex34... After reading all of this good advice, it seems that I’m running too much prop! Maybe that’s why it feels too fast running an oval. I’ve got an ABC 1815 coming in, that’s about 43mm. I know I’m turning the prop fast, so propping down seems the right direction. I have an 8s setup that turns the prop at 37,000rpm and the 4s setup is just a touch slower, 36,400rpm. I may end up selling my larger prop collection!
  10. #280
    2,912
    Craig
    An 1815 prop is 45.7mm NOT 43mm
  11. #281
    May 2017
    OK
    1,464
    I typed that wrong, it’s a 1715
  12. #282
    Jun 2007
    1,515
    Richard Templeman recently purchased the Pearl built by Sandy (Catboi) Squiteiri, here is his maiden run.
    https://www.facebook.com/10001112370...4167519297367/
  13. #283
    Jun 2009
    2,538
    Thanks for sharing Ray! Is he going to bring it to Michigan this year?
  14. #284
    6,192
    Hey Pete, if you think about it......the Pearl set the two fastest P sport two lap times in IMPBA. Pretty sweet.
    Wait until you see Ty's new one. Hope to have paint on it before the winter meeting.
    Noisy person
  15. #285
    Jun 2009
    2,538
    Very cool.....and those are the older hulls that set the records, without the better turning features and weight distribution changes! can't wait to see Ty's!!
  16. #286
    9,402
    Looks like I'll be building my 5.7.
    Nobody interestedmin buying it.
  17. #287
    Jun 2009
    2,538
    Well, I've run into some seriously uncanny bad luck! The original shop where I laser cut and vacuum form parts went bankrupt just days before I was going to make the next run. Then.....hard to believe this.....but the new shop that I just became a member of SOLD their vacuum former yesterday! I was going to run parts tomorrow! I just can't catch a break. Anyhow, those that are in the que, please be patient. I'll eventually get things moving here, but it's been a challenge to say the least!! Ugh!!!!!
  18. #288
    Nov 2008
    Ql
    3,169
    Man, that is a run of bad luck. Hopefully you've used up all of this years already, & it's plain sailing from now on.
  19. #289
    Sep 2007
    Co
    3,915
    I do not know if this will help But you can send the molds to me and I can do the vacuum forming. I do small runs about every two or three weeks.
    Randy
    BBY Racing
  20. #290
    Jun 2009
    2,538
    Quote Originally Posted by RandyatBBY View Post
    Holy crap!!! Thanks for the offer, Randy!!! I might just take you up on that if I can't get into another shop. Obviously, you could have the profits if it comes to this. Thanks!!
  21. #291
    Jun 2008
    GA
    2,318
    Your next version (HOW MANY ARE THERE) should have the same DECK contour as the UL1. The Aquacraft UL-1 hatch and nose cones are still available thru Tower.
  22. #292
    Jun 2009
    2,538
    That's not a bad option. It's where we started! It would require two separate pcs on the back half. The front would be the UL-1 (modified) and the back would be just another pc of styrene cut to size. It might limit width for the batteries though. I'll have to check it out. I'm hoping to laser cut more wood next week.
  23. #293
    6,192
    Priming this plug this week.
    Noisy person
  24. #294
    Jun 2009
    2,538
    You might have some customers! A lot of folks have been asking about a single pc canopy. I bet at least 20 people.
  25. #295
    2,912
    I reused the canopy off of my decommissioned N2 Sport Hydro.
  26. #296
    Aug 2009
    mi
    344
    that looks really good--tried it yet.
  27. #297
    2,912
    So far it runs pretty good, still working on a little more setup to get it better.
  28. #298
    Apr 2017
    mi
    26
    Not that I need another unfinished project but..... where might one purchase a pearl?
  29. #299
    Jun 2009
    2,538
    Charlie - I'll send you a PM.
  30. #300
    Jun 2009
    2,538
    That goes for everyone. I'm not much of an advertiser (actually, I've never advertised.....and somehow there are over 40 hulls out there in service!). If you are interested, shoot me a PM. I can email the instructions so you know what you are getting into prior to purchase. As I mentioned in the thread above, I'm a bit behind on cowls due to lack of vacuum forming ability, but I can get the wood cut soon.
    Thanks,
    Pete
