Results 1 to 24 of 24
Thread: Help with choosing solder
    Mar 2014
    Ca
    458
    Default Help with choosing solder
    I need help choosing the right solder.
    Building a Q sport hydro with 6s batteries, to power 1470 motor,
    8mm bullet connectors.
    My question is what is everyone using to solder the connectors for high current use?
    Any help will be appreciated.
    May 2009
    AB
    483
    A few years ago someone recommended this silver Kester and I?ve been using it ever since, it works great for me.
    Namba District 16
    1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joe, 1/8 Bud, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
    ON
    2,913
    Quote Originally Posted by pescador View Post
    Brian - that is the same stuff that I use. It was recommended to me by Castle.
    Larry
    May 2018
    TX
    344
    Source?
    Mar 2014
    Ca
    458
    I found this. I think it’s the same
    https://www.onlinecomponents.com/en/...&gclsrc=aw.ds#
    Mar 2014
    Ca
    458
    Thank you Pecador for sharing.
    Aug 2021
    325
    Any 60/40 solder works as well.
    Mar 2014
    Ca
    458
    Quote Originally Posted by jkflow View Post
    Thank you. Dumb question, since lead is a soft metal, isn’t it to soft for higher current draws using a 6s setup?
    I currently use silver solder but it is hard to work with.
    Sep 2007
    NC
    2,783
    Guys, you do not need silver solder.
    A good rosin core 60/40 electronics solder is what you want. Look for an .031-.062" diameter range which makes it easier to feed in. I would highly recommend a small 1oz bottle of liquid flux to help tin wires.
    90% of a good solder joint is prep technique and equipment. You will want a good 80-150W iron preferably with a chisel tip, a connector pinch tool or small vise to hold connectors while soldering and a heat resistant work surface like a silicone mat or phenolic plate.
    The most common error I see in high current joints is too much gap between the connector cup and the wire. If the wire has a loose fit in the connector try doubling the wire back on itself or balling up to make the wire fit snug. You do not want to use solder to fill large gaps.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Mar 2014
    Ca
    458
    Thank you Tyler for the info.
    ON
    9,402
    Come and get me coppers...
    Aug 2021
    325
    I use simple craft wire to fill any gap. I wrap it around the wire and solder it in place. As stated above, keep the gap to a minimum.
    https://smile.amazon.com/gp/product/B004CYFHQM
    ON
    9,402
    I just use solid copper because I have it and a lathe too. That same wire that is $7.99 USD is $16 - $30 CDN here. Our dollar is crashing, or has been for years now...
    As long as it works use what you can!
    Sep 2020
    Tx
    286
    Oh my gosh I love the copper inserts. I take Castle wire, cut a strand off, wrap it around the wire I?m soldering and twisting it tight, then soldering the whole thing into the bullet. Haven?t lost one yet since I started doing that, but that solid copper core is awesome!
    ON
    9,402
    I learned it all here.
  16. #16
    Oct 2009
    MI
    6,192
    .... and a lathe too.
    How is it that I own no lathe and no mill? Ridiculous.
    Noisy person
  17. #17
    ON
    9,402
    It's just a Taig,lol all manual by hand. Still gets the job done. I also have a tiny mill attachment. :)
    I wouldn't trust it to take a millimeter off a Tenshock motor case. I've taken the fins off a Neu motor with it and that was kinda scary.
  18. #18
    Aug 2010
    uk
    2,887
    I stay away from lead free solder, I prefer 60/40 or 63/37 as leaded solder flows much better.
  19. #19
    Mar 2011
    BC
    7,630
    Well look at the tip I picked up today, haven’t even finished my coffee. Another use for my Unimat lathe.
    Thanks for that one Ray.
    Terry if you don’t have a lathe look up a Unimat. Small affordable and versatile for small stuff.
    Shawn
  20. #20
    Jul 2016
    4,119
    COVID purchases for the shop... I'm no machinist, but they're incredibly useful.
  21. #21
    Aug 2010
    uk
    2,887
    You cant go wrong with the Sherlines for small stuff, very under rated machines for what they can do. much better & more capable than the old Unimats in my opinion. I have owned both Unimat & Sherline, but would choose my Sherline lathe any day over the Unimat.
  22. #22
    ON
    2,913
    My accumulation over the last 45 years of R/C
    Larry
  23. #23
    Mar 2011
    BC
    7,630
    well those are nice Ryan. Without the hassle of treatin* the equipment like a transformer
  24. #24
    May 2009
    AB
    483
    Mines just a Chinese combo but I added a DRO, wish I had it back in school it feels like cheating lol.
    Namba District 16
