Results 1 to 5 of 5
Thread: Seaking T180amp at 7S ???
    Jun 2015
    Ax
    73
    Default Seaking T180amp at 7S ???
    Hello.
    I want to ask if anyone have try the T180 at 7S and if it can handle???
    Is just for some saw passes
    The motor is TP 3640 2080kv
    Thanks....
    Jul 2012
    SP
    975
    Disable the LVC and you can get a try to this esc on 7S for some passes....did this with the 180 V2 time ago and it survived for some months.Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    Jun 2015
    Ax
    73
    Thanks...
    I think I'll try for two passes...
    Jul 2012
    SP
    975
    Take care with your only "two passes' ...have heard this many times with burnt esc's......downprop your boat and check temps and good luck.Gill
    www.grsboats.com.br
    Nov 2008
    Ql
    3,169
    I accidentaly ran one on 8s when I connected up 2 x 4s packs in series instead of parallel in a 32" mono with a 2200kv motor.
    It survived 1 lap before I realised my mistake & brought it in.
    Everything suvived. Even the bec in the ESC. Man it was quick though.
    But I think the 'Lady of the Lake' was looking after me on that day. I only mention it to show what they can put up with. Sometimes.
    I wouldn't reccommend doing it.
    So as Gill said for 7s, smaller prop & maybe one pass. Then check temps.
