SOLD
I repaired this hull after the flexshaft broke, tore open the stuffing tube and spun on the motor shaft a few more times which put a few small pin holes in the bottom of the hull and flaked off the outer gelcoat. All loose material was chipped away. The outside was skinned with epoxy and sanded with 400 grit. The inside was reinforced with fiberglass cloth and epoxy resin. I replaced the stuffing tube and teflon liner and epoxied in place. Boat ran great on 6S, did 56mph on a mild ABC prop. While tuning, I flipped it twice. The first time I attempted to rescue it with my Shoackwave, but even at slow speeds, it just ran right over the top, which is where the white scars came from, sharpened prop and rudder. Never bothered me enough to do anything about them. The hull looks great from topside. There are no signs of any cracks along the transom or side seams. I believe this to be the revised hull design where these areas were strengthened.
Hull will be shipped in the original Proboat box with original foam packing. Included are the drain plug, cooling hose aluminum grommet, battery trays, electronics tray, stuffing tube, teflon liner, and foam flotation. $100 shipped.
I'm also selling a stock Voracity motor in another thread.
2016-12-03 10.14.41.jpg2016-12-03 10.14.53.jpg2016-12-03 10.15.59.jpg2016-12-03 10.16.45.jpg2016-12-03 10.17.33.jpg
