Originally Posted by
RuntheraceAMC
My 5s and 6s packs are 5000 mah. I am putting 4600-4900 back in them each time I charge. On one or two occasions I have recharged them and it was over 5000 mah. My last run (when I noticed the abnormally high temps) it charged and it took 4800.
I also have two 6s packs I am running in parallel. 4100 each for 8200 total. I am recharging them 7200-8000 each time.
I don't time my runs. I quit when I notice a drop in performance.
A 5000 pack -- Recharging to 4800
This means that you are running your packs down to 4%
6S 2P 8200 packs --- Recharging to 8000
This means that you are running your packs down to 2 1/2%
These numbers are way too low.
You will start seeing the magic smoke if you keep this up.
You could be causing a lot of extra heat when the voltage drops.
The old rule for LiPo's for them to last for a good number of cycles is ;
Never charge over 98% and Never discharge below 20%
I run 2P setups of 10,000 total for racing.
My run times are about 2 min.
My packs are usually down to about 45%
My suggestion to you would do some testing; run 2 min. recharge to see what you got left.
Try again at 2 1/2 or maybe 3 min.
When you find your right point, then always time your runs.
