Page 2 of 2 FirstFirst 12
Results 31 to 33 of 33
Thread: NAMBA SAW Time Trials - Almost Here [Nov 11,12,13]
  1. #31
    ca
    6,962
    Ray,
    In general (until a change is made, which is likely to come), the current (I just checked) NAMBA approved motors for P-Ltd Cat are
    Brand Model Description
    AquaCraft AQUG7000 L36/56 7.2-18V – 6 pole brushless
    AQUG7001 36-56-2030 – 6 pole brushless
    AQUG7002 36-56-1800 – 6 pole brushless
    Himax HB3630 1500 brushless – 6 pole brushless
    ProBoat PRB3310 A3630-1500 – 6 pole brushless
    PRB4017 A3630-1800 – 6 pole brushless
    DYNM3835 A3630-1500kv – 6 pole brushless,
    water cooled, marine motor
    DYNM3830 A3630-1800kv – 6 pole brushless,
    iii) In addition, the CD has the discretion to allow the following:
    (a) An aftermarket motor that is a re-labeled and exact copy of any
    approved motor.
    (b) Any generational change of an approved motor, or a motor that
    is used in a Ready To Run (RTR) offering from a manufacturer
    that produces over 100 units of said offering, as long as there is
    no more than a 5% increase in any of the following
    manufacturers specifications as compared to any single
    approved motor: Kv, maximum constant amperage rating,
    mass, and MSRP.
    The class allows up to 10Kmah with no cell (up to 4 max) over 4.23V
    Length limit is 34.0000 inches.
    The current record is 67.77mph with my Drifter / Aq2030 / Turnigy 120 / Dinogy 3700's 4S2P / Snowman El Kabongo prop Several un backed-up runs over 70.xx mph btw
    If you want to do "SAW runs" with the DF cat, the 2030 with the right prop could be the ticket although Ray P. and company in Az are getting their P-Ltd Cat heat racers going max fast with 1500KV and bigger props. The CC ESC is always a good choice
  2. #32
    8,009
    Ray, the DF hulls have quite a bit of lift forward and will need an air dam at the front of the tunnel. There is an advantage with this short hull in using a smaller diameter prop to reduce prop walk. This will require a high Kv, and of the currently legal motors IMO the PB/DYN1800 is probably the best choice. It’s actual Kv is not much different than that of the AQ2030 motor. The AQ2030 motor quality has been spotty.
    High timing (15*-20*) is probably best. If you use high quality cells you won’t need more than 3300-4000 mAh. The ABC 17* props are currently the best. Consider a knife-blade prop, supercooling the motor/ESC and heating the cells prior to the run. Good luck!
  3. #33
    9,384
    Very nice guys. We'll see what I can come up with.
