Results 1 to 16 of 16
Thread: Revolt on 6s
    Aug 2015
    VA
    435
    Default Revolt on 6s
    Bought a used Revolt awhile ago that had been damaged and missing parts.Put the 1800 kv motor back in it with a 3/16 cable and no liner. Added some glass to the inside nose for weight, ran a M445 prop on 6s and got 53 mph everytime I ran it today.The temps stayed around 105 all day long.
    Sep 2016
    CI
    22
    What esc are you using for 6s and is it the aquaqcraft 1800kv motor.I have just bought one and I want to run it on 6s.
    Aug 2015
    VA
    435
    Quote Originally Posted by blindpew View Post
    I am using the 1800kv aquacraft motor with a seaking 120 esc. I measured a 2 oz. cup of rosin [epoxy works better] and poured in the nose for weight. Running a M445 prop. I also added a 3/16 flex cable with no liner and a peice of cooling tubing on the stuffing tube to help keep the water out.
    Sep 2016
    CI
    22
    Thanks for that I am going to order both the seaking 120 esc and the prop.I can not wait to see how she goes. Cheers.
    Aug 2015
    VA
    435
    Your gonna love it. First time out it ran 53 mph everytime and ran cool.
    Sep 2016
    CI
    22
    Magic.
    Aug 2015
    VA
    435
    Did you get your seaking 120 esc and prop?
    Sep 2016
    CI
    22
    I have the seaking 120 esc and the prop but I am waiting for a prop balancer before I try the prop. Cheers.
    Aug 2015
    VA
    435
    Been running 55 mph with some adjustments. Getting ready to put a Dynamite 6 pole 2000kv in her.
    Oct 2016
    pa
    476
    Quote Originally Posted by Revolt Flash View Post
    i wouldnt . your already running better then that 6pole 2000 will get you . thats the motor they use in the blackjack 29 v3 . it runs hot on 6s .if your running 55 and coming in cool with that aquacraft motor i would stick with that .
    thats been my experience with the motor .
    maybe the revolt is lighter so that might be in your favor .but that motor in my bj29v3 runs kinda hot .
    Aug 2015
    VA
    435
    Good to know. Thanks
    Aug 2015
    VA
    435
    Instead of the Dynamite 6 pole 2000kv, I went with a 180 ESC and a Leopard 4082 1600kv I had laying around.
    Oct 2016
    pa
    476
    hows that setup doing? doing something similar in my pursuit
    Aug 2015
    VA
    435
    Quote Originally Posted by boatsrnew2me View Post
    Just got it put in. I'll let you know as soon as I run it, hopefully this weekend.
    Aug 2015
    VA
    435
    Ran the Revolt with the Leopard 4082 1600kv, 180 esc and a m445 prop. 59.4 MPH and can do turns wide open. Have to ease on the throttle tho.20170622_152932.jpg
    Oct 2016
    pa
    476
    nice ,almost same setup in my pursuit .hasnt hit water yet though . i got the flycolor 150 esc and a b&s x645 from ose . should be a beast .a well seasoned builder recommended that prop for my setup so i trust in that .
