Results 1 to 4 of 4
Thread: Ambient temperature and lipo's
    Jan 2011
    ON
    497
    Default Ambient temperature and lipo's
    Hi all was running my 2s hydro over the weekend using Thunder power 2s 2700 mah Magna 70 c lipos in 2p format outdoor temp 45 farenheit gps read 37 mph 2 weeks ago outdoor temp was 80 farenheit and was getting gps reading of 41mph ? Could out temperature be a factor or should i be looking else where? Regards Andris Golts.
    AZ
    8,010
    Temperature absolutely is a major factor in LiPo performance (or about any typical battery for that matter). The higher the temperature, the lower the internal resistance and the higher voltage output. More volts = higher speeds. SAW racers usually heat their packs to ca. 120*F for maximum voltage.
    WA
    8,335
    To add to what Jay posted, when you "hit" a cold lipo with Amps, like I see many of you do in your videos (really should try to SMOOTHLY accelerate, not just PUNCH it...), you can damage/destroy your lipos pretty quickly.
    I'd actually contend that more lipos "puff" because of abuse when cold than overuse when hot.
    Darin E. Jordan - Renton, WA
    ON
    9,402
    Quote Originally Posted by Darin Jordan View Post
    This is very solid advice and I was reminded of some points I've forgotten.
    Steve Reesor used to always heat his packs and Randall Thomas is still running those same cells today.
    , nearly 5 years old.
