Results 1 to 6 of 6
Thread: Blackjack 29 V3 .187 upgrade shaft
    Sep 2016
    KY
    2
    Default Blackjack 29 V3 .187 upgrade shaft
    I purchased the upgrade strut and the .187 upgrade flex shaft for my blackjack 29 v3, can I use the 9/32 brass tubing with the .187 Teflon liner or do i have to use the 1/4 tubing without the liner? Is there enough material to mill the strut or tubing for fitment of the 9/32?
    4,100
    for a 3/16" (.187) flexshaft use 9/32" tube w/ .187 liner or 1/4" tube w/o liner. Seems like a lot of work to replace the 1/4" tube already in the hull. I would just pull the teflon liner and run the .187 OSE shaft that way. Looking at the strut on my V3, the nose cone tapers down from 11/32" OD to just a hair over 1/4", so you could probably modify the strut if you felt inclined to go the difficult road.
    Sep 2016
    KY
    2
    The bare shaft on brass tube won't produce too much heat to cause a shaft failure?
    Jun 2015
    Wi
    734
    Quote Originally Posted by Rayzor31 View Post
    Not if the cable is well greased every run and the motor is aligned perfectly with the stuffing tube. I have 5 boats they all run 3/16 cables with no liners
    Feb 2014
    In
    20
    Just remove the Teflon liner and run the 3/16th/.187 shaft on the stock tube. Been doing this for over a year at speeds of nearly 80mph on GPS....
    BlackJack-Miss Geico 29 V3 Leopard 4074 2200KV 78mph on GPS so far- FE Fun boat
    JAE 21GT B Hydro outrigger, Whiplash B Sport Hydro-Nitro Race Boats District-14
    www.ABMods.com
    Nov 2016
    44
    what prop are you using looks crazy fast and stable
