Results 1 to 20 of 20
Thread: Distance between props on twin drive
    9,402
    Default Distance between props on twin drive
    How close can a pair of counter rotating props be ?
    I've seen some as close as 6mm. Can they be closer?
    Since the rudder will be in the middle is there a certain distance the rudder needs to be away from prop wash?
    I was going to tinker with an old cat hull and some spare parts.
    Ken Joye built a Drifter with props close together back in the NIMH days.
    This is the closest set of big props I could find. No idea how it runs.
    9,402
    Nice pic. They look very close. I should be fine. Going to hack up an old Geico 29 for giggles. Most put motors in the sponsons but, I want to try something different. Might use a MM hull I've got around.
    Thanks Jay.
    Dec 2010
    3,119
    the closer the better just save enough room for bigger diameter props ,,,Da ? LOL
    4,119
    I love seeing twin screw offshore boats where they stagger the engines in order to get the drive shafts and props as close together as possible. It just looks so damn efficient in those engine bays.
    9,402
    Cool.
    Jun 2009
    GA
    595
    My largest prop will most likely be a 50mm so I did that plus 5mm. HPR Mono 45"
    Aug 2014
    WA
    87
    Aug 2010
    BW
    46
    1mm on my 50" lizzard with x447.
    With finalized sync gear -9mm with x457
    WR T-Mono 108.95mph
    9,402
    Wow, those are tight! Thanks.
    9,402
    https://www.rcgroups.com/forums/show...-L-FE-Cat-ARTR
    This is still awesome in my books. Finally found it in RCG from 2004.
    This is what I want to do to my GEICO, well, similar.
    9,402
    Quote Originally Posted by RunningBeer View Post
    Looking closely, I see your trim tabs are just home made angle aluminum. Is there any adjustment?
    Where did you learn this?
    Aug 2014
    WA
    87
    ...yeh a bit of guess work and I put out a call for help on OSE forum of course! I asked how high from the planing surface everyones tabs were on their pirates and ended up at @1.5mm. Then for width on the transom I tried them out wider (outside the props more) but it didn't hold the nose down in the straights. Getting the boat flatter in the corners was not too hard with rudder and strut angles, although a tiny adjustment on either had a large effect. I then moved them in close ( it didn't affect the amp draw at all) and the boat stays on the straight and narrow.....most of the time. Incidently now I'm running 44mm props, they're really close and I'm at my happy amp spot. I'd have to place the props further apart and go 5 or 6 s and lower KV if I wanted more prop depth. Cheers RB
    Aug 2010
    VA
    1,085
    The closer together you place the props the less need you will have to counter rotate. I have been racing big motor nitro outrigger twins for years and never needed to counter rotate (and they spin some big blades). I did do some counter rotation testing and actually found the boats ran better non counter rotating with the props close together. The Smokin' Joe's FE twin cat I have on the for sale page also does not counter rotate, tracks and turns beautifully.
    Futaba Team Driver
    - IMPBA Hydro Technical Director -
    4,119
    Quote Originally Posted by don ferrette View Post
    Very interesting
    9,402
    Back in the Nimh days...
    9,402
    BUMP for reference.
    7,631
    I did this on my second FE R-42 Ray. First one I put the struts on the sponsons but the second one I put motors on the tunnel and struts in the tunnel. The result was the second boat just turns on a dime. I’ll getsomepics later today for you
    9,402
    Nice, thanks!
    7,631
    Nice, thanks!
    Ray I?m not of much help on this as I?m sure I was running 447?s or maybe 445?s on the R42 light and the struts are spaced 75mm apart. I guess I had the rudder actually in front of the props when I last ran it. I broke the motor mount and flex blah bah on that last run.
    Stuff is kinda stacked, haha
