Results 1 to 8 of 8
Thread: need advice on a compact simple charger for a friend.....
    Aug 2010
    VA
    1,085
    Question need advice on a compact simple charger for a friend.....
    A friend of mine who runs nitro and gas boats uses a flow meter powered by a small 2S lipo pack. I'm trying to help him find a SIMPLE EASY TO USE charger. He has seen my Hyperion chargers and has no interest in something so complex, can't blame him for what he needs. Does anyone make a basic inexpensive "wall wart" (plug in AC wall outlet) that will properly balance charge his pack without having to be a rocket scientist to make it operate?
    Futaba Team Driver
    Aug 2010
    VA
    1,085
    40 views and no input?
    Futaba Team Driver
    ON
    2,908
    Don
    Here is a good one for your friend;
    https://forums.offshoreelectrics.com/...A-10-Balancers
    Larry
    Ga
    5,266
    Hey Don,
    This may be as simple as it gets.
    http://www.hobbyking.com/hobbyking/s..._US_Plug_.html
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    May 2014
    mi
    643
    Hi Don
    I have one of these and its great for small 2-4s packs.
    it will do two 2s packs at once. super simple to use.
    Jul 2007
    642
    Hey Don,
    I always have a Turnigy Accucel6 available.
    It has built in balancers and is very simple to use.
    I have actually taken it to the Bahamas with a T-mono
    because of it's small size. the best for charging all
    of my Rx packs too. It can pretty much charge anything
    and has up to a 6 amp charge rate.
    http://www.ebay.com/itm/Balancer-Cha...kAAOSwuhhXVegd
    The price is right too !
    TenShock Brushless / Pro Marine
    NEU Motors / Rico Racing/ Castle Creations
    2023 NAMBA & 2018 IMPBA FE High Points "National Champion"
    Sep 2016
    WI
    9
    Hello! Looking for a lipo charger myself. Does this charger have an option for 'storage'? I've seen some chargers that have an option that brings it to storage levels if you're not gonna be using the battery for a while. Is 'storage' a must for lipo's? Thanks!!
    Sep 2016
    Az
    Hi...i am a new user here. I think you should go for Turnigy Accucel6.It has built in balancers and is very simple to use.
    It is also available with a T-mono and because of it's small size it is the best for charging at all for Rx packs too. It can pretty much charge anything and has up to a 6 amp charge rate.
    rapid smt assembly
