I recently got back into the RC boat hobby after discovering how far things had progressed with lipo batteries and brushless motors. I bought a couple of UDI RC boats for the kids off Amazon, and am cutting my teeth on a Blackjack 24 I picked up on craigslist. Between the first few runs and a lot of threads I've read online, the typical Proboat shortcomings have played out and I'm taking care of them with aftermarket parts as needed.
Shortly after the first run, I drilled out the cooling pick-up on the rear rudder. Next trip to the pond, there was a noticeable improvement in output from the side of the hull. I think I'll eventually install an additional pick-up on the bottom of the hull and cool the ESC and motor separately. I also shimmed the rudder push rod at the servo horn with a home made plastic washer and a little super glue. That firmed things up and took a fair amount of slop out of the rudder. I had used a collar style attachment on my old nitro tunnel hull rudder, but my box of spare parts are long gone so I worked with what I had.
When I got home after the second time out with the boat, I pulled the flex shaft to grease things up. Figured I was staying ahead of the game. Nope. Next trip out, lost the flex shaft and prop 10 seconds into the run. I ordered two new stock flex shafts (didn't know about the upgraded options yet) and a PRB282006 1.6"x2.5" stainless prop from Proboat. The new prop gave the boat a little extra speed and the motor and battery only appeared slightly warmer to the touch after a full run.
