Results 1 to 8 of 8
Thread: Miss geico 17 help please
    Apr 2016
    Wi
    10
    Default Miss geico 17 help please
    I have a miss geico 17 I modified to brushless. I put a leopard 2550kv motor in it. It's very unstable at high speeds on my pond. Can I put turn fins and trim tabs to help stabilize it?
    Jun 2015
    Wi
    734
    Front end bouncing? Or like rocking from side to side?
    Apr 2016
    Wi
    10
    It has a lean on one side but most likely a leak in the flush mount water pick up. It wants to roll though when you punch the throttle.
    9,402
    Counterweight. Can you shift the battery to the lifting sides bit?
    Apr 2016
    Wi
    10
    The battery only fits one direction which is straight across the center
    9,402
    I looked at the inside and it seems like the battery is held by Velcro and easy to shift a little one way or the other but I could be wrong if yours is different from the pictures.
    Apr 2016
    Wi
    10
    That's the correct inside view. I'm running lipo 3s 1300 battery. It's longer than the factory battery
    9,402
    Can you try to fit it in the left sponson? Center it lengthwise?
    other than that add a little weight t o left sponson.
