I recognize that motor!
I wouldn't personally run that motor on any more than 3S... At that, you'll have about 38,000 RPM...
I'm not sure it'll be controllable in that hull, but you can try... 4S would give you around 51,000RPM and that's just silly... I'm not sure how long it would last at those kind of revs...
That boat should get well into the upper 40s.... maybe even low 50s with the SV27 setup you have in it... and the right tuning, but I'm not sure the hull is going to handle it all that well... It just was not designed for those kind of speeds...
Darin E. Jordan - Renton, WA
