Results 1 to 3 of 3
Thread: Swordfish 220A-6S ESC problems ?
    Jan 2011
    497
    Default Swordfish 220A-6S ESC problems ?
    Hi all plugged in 4s lipo got several quit beeps but the motor would not turn on! The TX im using is the Spektrum DX3S . What other parameters can i check ? Im at a loss at what to do. Regards Andris Golts.
    Jan 2011
    cq
    56
    Board Transmitter
    1st: Connect ESC to motor, plug receiver lead of ESC to throttle channel of RX.
    2nd: Push joystick of transmitter to max throttle position, power on TX.
    4th:
    In the following, motor will emit four long beeps in flat tones.
    After any one beep of the four long beeps, pull joystick to
    zero immediately.
    3rd:
    Power on receiver, connect ESC to battery. Motor emits three beeps in drop
    tones.
    Then motor emits two beeps in up tones.
    5th:
    Calibrating is completed, it’s ready to go.
    9,401
    After calibration, please shut down RX, and unplug main pack from esc, reconnect, turn it all back on, wait for an initialization beep and test throttle and steering.
