Results 1 to 6 of 6
Thread: Timing for t600 1250kv outrunner
Hybrid View
    Aug 2008
    He
    649
    Default Timing for t600 1250kv outrunner
    Just ordered 2xTurnigy Marine 180A esc´s for my big cat project(expresscraft thunderbolt)
    https://forums.offshoreelectrics.com/...th-twins/page2
    The motors are SK3 helidrive T600-1250kv
    Cant find that much info on these but I think they have 25 /steps when rotating 360 deg.
    edit:new version of this motor:
    Specs.
    Turns: 6T
    Voltage: 6S~10S Lipoly
    RPM/V: 1250kv
    Motor Poles: 8
    Internal resistance: 0.0077 Ohm
    Max Loading: 115A
    Max Power: 4250W
    Shaft Diameter: 6mm
    Shaft Length: 21mm
    Screw Mounting Spacing: 25mm/30mm (M4)
    Weight: 372g
    Motor Plug: 4mm Bullet Connector
    http://www.hobbyking.com/hobbyking/s...ize_heli_.html
    thinking 15deg timing to try?
    ON
    9,402
    Try to count number of magnets.
    Aug 2008
    He
    649
    AZ
    8,010
    Most helicopter outrunners run best in boats with around 15 degrees of timing advance.
    ON
    9,402
    Yep, 15 is good, 8 pole motor, nice. Slightly better than the T600. yours has an aluminum cover pressed over the steel magnet holder for magnet heat dissipation.
    Aug 2008
    He
    649
