Results 1 to 17 of 17
Thread: Fs: aeromarine mean machine 2
    Nov 2013
    ok
    211
    Default Fs: aeromarine mean machine 2
    Aeromarine mean machine 2 artr just needs rx/tx. Poseidon 2200kv motor, seaking 180 esc, hull has been reinforced, savox servo. This is a 70mph plus boat. The boat is in great condition. The black Vinly decals
    can come off. Sold
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    Jun 2015
    205
    Nice MM, do you run this setup on 4s?
    Sent from my cell using Tapatalk
    Nov 2013
    ok
    211
    Quote Originally Posted by ChevyPrerunner View Post
    I goes 50s on 4s and 70s on 6s
    Jan 2016
    1,464
    is the poseidon P1420 or P1515? with 6S how's the temp
    What is holding the servo in place? It seems not to be attached to the servo mount, perhaps glued down? Thanks.
    Jan 2016
    1,464
    i was wondering the same thing. . .I figured paul just put there for pictures, probably has servo mount but not mounted yet. hopefully it's not glued down
    Nov 2013
    ok
    211
    Quote Originally Posted by Bp9145 View Post
    1515, temps are good around 120 after a full battery pack. The servo mount is epoxy down and servo screwed into the mounts
    Mar 2016
    BZ
    970
    What size is this boat?
    Mar 2016
    BZ
    970
    Is that a c6-R????
    Nov 2013
    ok
    211
    Quote Originally Posted by Keagan-Z06 View Post
    The boat is 33" x 11"
    Nov 2013
    ok
    211
    Bump
    Aug 2008
    7,080
    I thought the mm was closer to 30"... Is this 33" including hardware?
    "Look good doin' it"
    See the fleet
    Nov 2013
    ok
    211
    Yes
    Jan 2013
    nc
    198
    I thought it was 29 by 11
    Mar 2010
    ME
    3,438
    Mean machines are 29" long
    Mar 2008
    535
    Bottom dollar?
    Nov 2013
    ok
    211
    It's sold
