Results 1 to 4 of 4
Thread: can not see log
    Feb 2014
    ZH
    26
    Question can not see log
    after uploading data from ESC, program stalls and following message comes up:
    runtime error HifeiV4.11.exe
    This application has requested the runtime to terminate it in an unusual way.
    Please contact...
    I set the poles to 8 and tried version 5.02 with similar results.
    May 2014
    636
    I think that Windows, by default, does not give the program rights to complete the task. I was told to run the program as administrator, and it always completes and displays the log. The technique is to put the mouse pointer on the shortcut, then right click, and select "run as administrator". BTW - the poles have to be set correctly in order to compute the RPM.
    Ron - The Villages, FL
    Feb 2014
    ZH
    26
    works! thanks
    May 2014
    636
