Page 9 of 9 FirstFirst ... 789
Results 241 to 268 of 268
Thread: ML Boatworks RSX310 , My 1st Outrigger design ever! 31", P/ P-ltd FE Rigger!
  1. #241
    ON
    9,402
    Got the sponsons all tacked up. If you use Zippkits boom tube holders you have to put the front ones in before putting the doubled part in or you will be stuck. I did remember this however I made another mistake that I had to Debond the CA glue tacking and remove, clean, reposition the inner stringer. All is good now with tons of help from Mike who was just a message away.
    Great customer service for sure!
  2. #242
    Jul 2008
    VA
    3,225
    Quick question Mike, does the RSX240 feature the same turn fin or has it been scaled differently? Thanks.
    Also, please send me a text and let me know what size lipo will fit in the smaller hull. Will 2p fit?
  3. #243
    Sep 2010
    MI
    589
    Default Same mistake
    Did the same thing Ray! Unfortunately mine were epoxied on already! I ended up spinning the heads down on a lathe.
    Bob Zola NAMBA 212
    2022 NAMBA Nationals FE High Points Champion
    Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
  4. #244
    ON
    9,402
    I was tempted to do the same. I was at Wendy's place and my lathe is 1.5hours away.
    How did you set yourself up, full P or Limited power?
  5. #245
    Sep 2010
    MI
    589
    Hoping it will work for both with motor change.
    Bob Zola NAMBA 212
  6. #246
    ON
    9,402
    Quote Originally Posted by mojoracer View Post
    Me too.
  7. #247
    ON
    9,402
    Any pictures of the business end Bob?
    Top secret? Lol... I better try my own thing instead of riding coat tails.
  8. #248
    Nov 2008
    Ql
    3,169
    Ray.
    Post #11 in this thread shows how I did mine if it is any help.
    https://forums.offshoreelectrics.com...ghlight=rsx310
  9. #249
    Sep 2010
    MI
    589
    My RSX310 is nearing completion! Put a coat of primer on it today. Motor mount is in, all hardware holes are drilled and stuffing box done. Just need to bend the 1/4" tube and finish painting. Cold day out in the garage, but the catalyzed primer seems to be setting up fine!
    Bob Zola NAMBA 212
  10. #250
    Nov 2008
    DE
    2,322
    Looks Good Bob!!
    "Will race for cookies!"
    IMPBA D12
    My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
  11. #251
    Sep 2010
    MI
    589
    Here ya go Ray. No Mojo speed secrets on this one..... Tube was easy and gentile bend. Motor mount is a raffle prize I picked up along the way (and OSE sells them too). I put the mount in with Epoxy and pop rivets from underneath. I also added 1/8th plywood to the tub floor in the motor area. I did shim the mount to get more angle. I set the motor to clear a TP 4060 if need be, but probably will run the little NEU motor for P. I also re-did the 5/16th tube after the photo to get better flex alignment. Using Speedmaster small extended strut and mini rudder. Rudder and strut brackets are tight together. I am using a Castle modified airplane ESC that Mr. Buaas did for me. Battery options I am looking at are a single 4S 6000 or pair of 4S 3300s (tight fit)! Will probably run a single 4S 5000 for limited set up. Enough room in the tub for multiple battery configurations!
    20180331_153538.jpg20180331_153454.jpg20180331_153506.jpg20180331_154606.jpg20180331_154700.jpg
    Bob Zola NAMBA 212
  12. #252
    ON
    9,402
    Very nice, thanks!
    You shimmed the front of motor mount or rear? Looks like the front.
    What is the extra pad for the turn fin? Is that to put it in clean water?
    Thx.
  13. #253
    Sep 2010
    MI
    589
    Very nice, thanks!
    Thx.
    Front of mount to get more angle. 2nd item yes...
    Bob Zola NAMBA 212
  14. #254
    ma
    8,694
    Thanks for sharing. Your 4s Giant Power packs fit nicely in there! There is a ton of room.
    Steven Vaccaro
  15. #255
    Oct 2008
    CO
    9,488
    looks like lots of room in there
  16. #256
    Mar 2009
    NC
    2,908
    Finally, a full instruction manual for the RSX series is done! Email me for a copy anyone that needs one!
  17. #257
    ON
    9,402
    Can someone advise me on the size of bolts used to secure the sponsons to the booms?
    Someone said they used 2mm bolts and tapped the carbon rod. I don't have any 2mm bolts around and not enough 2-56 bolts.
  18. #258
    Jan 2014
    Md
    323
    Ray Someone ment to say 3/32 not 2mm. I hope that helps you.
  19. #259
    ON
    2,918
    A #4 is 7/64" or 2.8mm
    A #2 is 2.1mm
    So what size bolt is 3/32" ??
    Larry
  20. #260
    ON
    9,402
    I'll see what I can find at local vendors.
  21. #261
    Sep 2010
    MI
    589
    Bob Zola NAMBA 212
  22. #262
    ON
    9,402
    Nice work Bob!
  23. #263
    Jun 2007
    1,515
    My take on the RSX310
  24. #264
    Oct 2008
    CO
    9,488
    That is sweet!
  25. #265
    ma
    8,694
    Ray that looks great.
    Steven Vaccaro
  26. #266
    ON
    9,402
    I wonder how much you shimmed the front of motor mount?
    Hello Bob! lol... Yeah, still not done but I just need to rig and paint.
  27. #267
    Sep 2010
    MI
    589
    Looks like 1/8" plywood Ray.
    Bob Zola NAMBA 212
  28. #268
    ON
    9,402
    Thanks Bob. Your rudder mount overhangs a bit on starboard side I guess???
