Results 1 to 25 of 25
Thread: Castle 1515 Actual Kv
    Jul 2011
    AK
    19
    Default Castle 1515 Actual Kv
    What is the actual measured Kv for a Castle 1515 1Y motor? How about a Neu 1515 1Y? I measured my Castle 1515 1Y to be 2350 rpm/volt. Just wondering if this sounds correct? I used the data log from my Castle ESC and also verified it with my Snapon Photo tach. Thanks
    Nov 2012
    De
    356
    My castle 1515 has 2200kv on the box
    AZ
    8,010
    The actual Kv will vary depending on the load and voltage. The 2200 on the box is an approximation to guide the consumer in his choice of motors
    May 2014
    636
    Quote Originally Posted by NeverEnuff View Post
    Could you explain how you are getting kv readings or calculations. Thanks.
    Ron - The Villages, FL
    Jul 2011
    AK
    19
    I connected a 2s battery and ran the motor no load at full throttle for a few seconds, after downloading the data log from my Castle ESC and looking at the data it was 16653 rpm at 7.0 volts = 2379 Kv. Next I did another run holding my Snap-On photo tach to the end of the motor shaft to verify the rpm reading and I got 16,100 rpm from the photo tach and looking at the data log the voltage was about 6.9 volts for a 2333 kv. Fluid, thanks for the response, I might repeat the test with 3s to see how much it changes. I don't know if I would want to go full throttle/no load with any more voltage than 3s.
    See attached data logs
    May 2014
    636
    Ah-ha. Now, I am going to try that with my Swordfish logging ESC. What do you put onto the shaft for the photo tach to read? I am also an airplane guy, so I have used a suitable coupler and popsicle stick.
    I have one of those HobbyKing kv meters, and it's off by a lot (and I do verify the number of poles).
    Thanks a lot.
    Oct 2008
    CO
    9,488
    Interested to see how more testing like this goes...
    Jul 2011
    AK
    19
    I have an older version of one of these:
    Then I used the cone attachment and pressed it up against the end of the motor shaft.
    Oct 2013
    la
    8,740
    I've tested a few castle 1515's with my kv tester and they were almost dead on 2200kv (2222kv comes to mind).
    Oct 2008
    CO
    9,488
    Quote Originally Posted by kfxguy View Post
    That's good to know..
    Jul 2011
    AK
    19
    So I reran the test on 2s, 3s, and 4s. The kv does go down as voltage increased. Here are the results from that test. (This is no load on the bench)
    2s = 2373 Kv
    3s = 2347 Kv
    4s = 2322 Kv
    AZ
    8,010
    Cool
    Testing at zero load tells you little about the motor's performance. What we care about is the Kv under load.....unless we don't run our boats in water.
    An example is Neu (and many others) who obtain their Kv unloaded. OTOH Lehner tests their motors for Kv under load. If you choose a Neu and a Lehner both with the same listed Kv, your boat with the Neu will be a lot slower given the same prop.
    Data logging on the water comparing the actual pack voltage to the motor rpm - at the same time - tells you the true Kv.
    Jul 2011
    AK
    19
    I figured that I would update this thread after running my JAE FE 21.
    Data from Castle ESC data log and speed from Eagle Tree GPS data log.
    #Cell Voltage Current Watts RPM KV MPH
    4s 13.3 125 1664 26940 2025 68
    5s 16.0 158 2534 32254 2015 82
    6s 20.2 194 3888 35243 1744 91
    Castle 1515 1Y, Castle Converted Mamba XL2, Revo427 4800 batteries, 1817-17-45 prop
    You can see the motor on 6s did not like the 1817-17-45 prop. I'm sure the full size turn fin and rudder are not helping at 91 mph.
    Oct 2013
    la
    8,740
    I bet it would go faster with a 1815-17-45 probably with every voltage setup. The 1817 is ALOT of prop for that motor.
    Jul 2011
    AK
    19
    My Bad. I had a typo on the prop. It actually was a 1816-17-45.
  16. #16
    Oct 2013
    la
    8,740
    I still think you should try an 1815. I think it will go faster. I run all these props on my boats.
  17. #17
    May 2014
    636
    How the heck do you get an Eagle Tree and 6 cells in there? Also, what version goes up to almost 200 amps? I have the 150 amp version. I thought it stopped there.
  18. #18
    Jul 2011
    AK
    19
    Kfxguy
    I will have to give that prop a try. Thanks for the suggestion.
    Zooma
    Space is tight. I put everything in AutoCAD to make sure it would fix. I've been working out of town but I could take a picture when I get home if you would like. The eagle tree is just for data logging GPS and temp data, the Castle ESC covers everything else. You could do the 300 amp mod to your eagle tree if necessary?
  19. #19
    ON
    9,399
    Has anyone confirmed the smooth newer 1515 is the same as the old finned version? The smooth cans are so much cheaper to get these days....
    That is a tight squeeze into a Jae 21!!!
  20. #20
    May 2014
    636
    Kfxguy
    Zooma
    That's OK. I have seen some spikes over 150, but generally I am well under. And, I think it has some headroom. BTW - the thing gives me fits on Windows 10. I have to reset power management almost every time I plug it into the USB port. Does that happen to you?
  21. #21
    Jul 2011
    AK
    19
    No, but that is great info for challenges that Windows 10 can create. I have been wanting to upgrade my computer, but not looking forward to all the problems that arise when upgrading software. I'm still on windows 7 Professional.
  22. #22
    Mar 2011
    BC
    7,629
    And I shall remain on Win 7 for just these reasons.
    The EagleTree will handle spikes over 150. I have seen 170-190 even in spikes but they settle down to 100-120 and less. If you reduce the capture rate you will see less spikes.
    On another note, if you run an ET you can get the Hall effects RPM sensor and then you'll know what REAL rpm you are spinning. Takes a bit to get set real nice but I am running up over 45k rpm and it seems good.
    Shawn
  23. #23
    Jul 2011
    AK
    19
    How much RPM difference are you seeing with the Hall effects sensor? I realize lots of variables can effect this, but what is a rough average?
  24. #24
    Mar 2011
    BC
    7,629
    Actually I have been surprised at how close(efficient) the TP's in my setup are. I haven't ran that one since fall so I'll have to look up the logs. It is all ready to go ATM tho. Soon, very soon!!
    I'll try to take a look tonight and let you know.
  25. #25
    May 2014
    636
    Shawn
    I'll try reducing the capture rate. Thanks
