Page 3 of 9 FirstFirst 12345 ... LastLast
Results 61 to 90 of 249
Thread: Pro Boat Formula Fastech Jet Drive Project
  1. #61
    Jul 2008
    CT
    133
    Hi Jesse;
    "Great video! looks like fun! was that full throttle? I was thinking of putting in a sc 700 or like you say XL brushless. I will be watching for more videos under bl power!"
    Some of it was full throttle, it is a lot of fun, remember to keep the boat up stream so if it dies or turns turtle you can catch it.
    ---"How is that hull? would it be worth laying down some good sturdy fg before construction? Do you have any shots of the transom? How do you mount up that jet?
    --- YES it would be worth a layer of glass or carbonfiber on the inside. Not just the bottom, the strakes make the bottom very strong. I have a couple of major cracks in the sides of the hull. Study the instructions for the Jet, drilling that huge hole in the transom is a major move. Both of the heavy gray plastic pieces go on from the outside then the white water duct goes on the inside. So cut and fit the housing and nozzle(gray parts) before cutting the hole in the bottom of the boat.
    Leave the Vee hull alone ! The less boat in the water the better. A big flat pad is just drag.
    Viking
    That Viking www.How2RC.com PULSO
    Home made 36" DeepVee 50mph
  2. #62
    Mar 2007
    VA
    7,212
    Quote Originally Posted by Viking View Post
    Viking
    I would have to disagree. Not only would that be wrong, the flat pad makes it easier to marry the jet drive to the hull.
    Quote Originally Posted by Tips & Info
    The Shallow Vee has a much flatter bottom which when at full speed has less of the hull touch the water. This make the Shallow Vee faster. But the Shallow Vees tend to slide around corners, instead of carving the turn. Below is a picture of a transom with much less angle.
    If a flatter v is faster than a deep v, then a flat spot should be "less" drag.
    Source
  3. #63
    Jul 2008
    CT
    133
    Default Flat Spot
    Hey Diego;
    You are quite correct the flat spot would make it easier to install the jet.
    The shallow Vee is faster than a Deep Vee with a prop for the simple reason that it is easier to keep the hull out of the water.Less drag.
    With a Jet boat if the hull is out of the water, it is not picking up water and so there is no thrust. A Jet can't be aired out like a prop boat the Jet intake and so some of the hull Must be in the water to maintain thrust.
    No, Yes, Maybe???
    Viking
  4. #64
    Mar 2007
    VA
    7,212
    True, but lets take a look at surface area for just a moment.
    Look at the picture... I'm no math genius, but I see less hull in the water. take that number and multiply by the length of the hull, I see a huge amount of difference.
  5. #65
    Aug 2008
    7,080
    I am on Diego's boat on this one. Also, flat bottoms support weight better by spreading the displacement out over less surface area as the drawing shows. The mere fact that it would help the intake alone, not to mention we are not talking super speed boat, almost makes it worth it. I was picturing flattening just the back half or so, kinda like the Fastech. The EV tends to flop around a lot, being severe deep vee and so top heavy.
  6. #66
    Mar 2007
    VA
    7,212
    I wonder why all jet ski's, seadoo's, etc... are NOT deep V hulls?
  7. #67
    7,279
    When is this thing going to be done so I can buy it.
  8. #68
    Mar 2007
    VA
    7,212
    Doby, So you want this boat AND the Graupner rigger?
  9. #69
    7,279
    Nahhh, not the rigger, its cool but not my thing.......the jet drive IS VERY Interesting!!!
  10. #70
    Mar 2007
    VA
    7,212
    That's cool, because EyeKandy is first in line for the Rigger!
  11. #71
    Jul 2008
    CT
    133
    Hey Diego;
    Jet Skiis, Personal water craft, what ever, are made to be very maneuverable. They would be a lot less fun if they were deep Vee's. One of those jet skiis in your photos is a modified V some place between a shallow and Deep V.
    Viking
  12. #72
    Mar 2007
    VA
    7,212
    True, but they both have the infamous "flat spot" on the hull.
  13. #73
    Mar 2007
    VA
    7,212
    Here's the steering servo installed.
  14. #74
    7,279
    Still waiting to buy this thing..............................
  15. #75
    Mar 2008
    So
    1,006
    Im still waiting to see it go...
  16. #76
    Mar 2007
    VA
    7,212
    Quote Originally Posted by calcagno45 View Post
    Me too!
    I have completed a custom "quick release" motor mount for her, I just need to install the mount and couple it to the drive. Then she's ready for the water! (still needing turn fins though)
  17. #77
    Feb 2009
    ut
    28
    i dont think that jet drive is big enough to power that boat there is still room under the hood
  18. #78
    Mar 2007
    VA
    7,212
    Quote Originally Posted by skipskip View Post
    I hope that's sarcasm skipskip! That jet is made to push a MUCH bigger boat!
  19. #79
    7,279
    Crickets......
    Chirp,,Chirp......Chirp.........................
    Yawn..........................
  20. #80
    Mar 2007
    VA
    7,212
    Ok Doby. I'll get back on the ball tonight and tomorrow. Expect an update soon.
  21. #81
    Feb 2009
    ut
    28
    ya its sarcasim im mean come on do thay even make a bigger jet drive that out let takes up the hole back of the boat
    oh baby
  22. #82
    on
    1,921
    you should get a BIG motor for it maybe a Fieago 580
    EYEKANDYGRAPHICS
    www.rclipos.com
  23. #83
    Jul 2008
    CT
    133
    Default turn fins
    Hey Diego;
    Why is it again you think you need turn fins on a jet boat. If you have enough power to the jet it will turn in it's own length at full speed and be going the other way while everything else on the water is still thinking about turning!
    Viking
  24. #84
    Mar 2007
    VA
    7,212
    Because my 1st jet boat, Shockwave 26, would just spin out in a turn.
  25. #85
    Jul 2008
    CT
    133
    did it have one of those flat spots?
  26. #86
    Mar 2007
    VA
    7,212
    Why yes it did, as a matter of fact.
  27. #87
    7,279
    ZZZZZZZZZZZZZZZzzzzzzzzzzzzzzzz,,,,,,ZZZZZZZZZZzzz zzzzzzzzz,,,,ZZZZZZZZZZZZzz,,,,
  28. #88
    7,279
    ZZZZZZzzzzzzzzzzzzzzzzZZZZZZZZZZZZzzzzzzzzzzzzz,,, ,Zzzzzzzzzzz ,,,,Yawn,,,,,,,, 4 months to buid one little jet boat,,,,,,,,
  29. #89
    Va
    4,670
    Glad you aren't watching my shovelnose build!
    IMPBA 20481S D-12
  30. #90
    Mar 2007
    VA
    7,212
    2-56 push rod is now replaced by a beefy 4-40 rod.
