Page 2 of 2 FirstFirst 12
Results 31 to 55 of 55
Thread: Mamba XL X
  1. #31
    Mar 2008
    974
    I have blown up 3 Neu 2230 on my sf300 at saw events and it still works. That's why I think Rays 300 may have been on the way out. But, we will see how mine does on my motor. I will also bring my castle 160 with me to test as well. It's anybody's guess how many amps a boat set up is going to pull. My motor is only rated at 180 amps for constant running so I hope it's not too much of an amp hog.
    Mark
  2. #32
    Dec 2013
    az
    1,228
    The mamba xlx I have pulled over 300 amps.. I have seen brian pull over 270 on his .. the 160 and xlx are same board basically.. and if u go into setup both have same limits
  3. #33
    Mar 2008
    974
    The good thing about the 160 is I can go in and get a ruff guess on amps pulled.
    Mark
  4. #34
    Sep 2007
    Co
    3,915
    Quote Originally Posted by rayzerdesigns View Post
    It's the same case as the xl2 so easy to convert to water cooling.. Does have 4 more caps that make overall length longer.. As far as performance.. I like the adjustable bec.. And running the 2 back to back it runs on average 30 to 40 degrees cooler than the xl2 with same exact setup in same boat and motor and prop..and have spiked it well over 275 amps.. Just wish they were a bit more waterproof
    How do you know? the castles have no data recall.
    Randy
    BBY Racing
  5. #35
    Jul 2007
    or
    1,088
    Castle ESC's have had data logging since the Ice series was introduced. XLx has logging.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
  6. #36
    Sep 2007
    Co
    3,915
    thanks for the response Brian.
    So the Mamba Monster 2 is a older ESC than the ones with data logging
    Randy
    BBY Racing
  7. #37
    Jul 2007
    or
    1,088
    Yes. It's based on the older Monster design. The Monster X has data logging.
    This is from memory, the original Monster was from the same era as the original hydra design.
    NAMBA FE Chairman
  8. #38
    May 2007
    1,603
    Hate to revive an old thread but I know if I start a new one I will get hammered. I recently picked up a telemetry radio that works with any of the Castle X series controllers. I have been running the 200 amp Castle Ice controllers in my boats with good success and wondered how you guys were making out the the Mamba XLX controller in the boats. I don't run saw so I am sure I won't be pushing them that hard.
    Team Liquid Dash
  9. #39
    Jul 2015
    638
    I’m wanting to convert a castle ESC to water cool but can’t find the post from last year where a guy made one clean in a solid epoxy cube ,my question is do I need to add special cap banks ? Planing on using XLX ,thanks
  10. #40
    Dec 2010
    3,117
    Quote Originally Posted by MG1234 View Post
    KFX guy has a post around here showing that !!!
  11. #41
    9,398
    Although I've never tried one I've seen people convert these to Water cooled esc's. It's board layout is the same as the Castle series like the XL-2 but it's a knock off. Sometimes these go on sale for less than $100.
    Sky RC https://hobbyking.com/en_us/turnigy-...o-car-esc.html
  12. #42
    Jul 2015
    638
    Thanks ,now for caps,can I get a cap bank from the store here and properly install it ? Is it nessesary? I’ve seen some for sale that didn’t have caps added ,I’ll add them I just don’t know how to make sure they are correct if it’s really that close or can I over kill it and be safe?
  13. #43
    Mar 2015
    1,262
    So the mamba XL X’s are rated at 160amp? Figured they were same as the edge 200
  14. #44
    Oct 2008
    9,488
    for a while now I have been tempted to try one of those in P and Q.
  15. #45
    Mar 2015
    1,262
    I wouldn't bother with SkyRC version -- too many bad reviews with smoke. Concept looks good tho. Trackstar appears to be the more reliable version.
    I've realized with these china/hobbyking controllers... even with the $200 ones is that there always is a "deficiency"... where they use cheap PCB/design, knock off/obsolete/used/old surplus Fets -- all to obtain maximum profits.
    They have to make a controller for $100 and STILL be able to make a profit. It has to come from somewhere. Most modern brand name Fet chips cost as much as the controllers are being sold for.
    Firmware is a whole other story. Bad firmware adds to the low performance... (unless its a clone of a brand).
    BUT that doesn't mean we can't modify and improve them a bit to make them less prone to smoke. Gonna try flashing the firmware of some of my cheap controllers just to see if theres any improvement with using opensource firmware like BLHeli and SimonK.
  16. #46
    Sep 2007
    Co
    3,915
    Some times the cheap ESC can be used for light duty. Case in point I have the new Whiplash with a Pro Boat 1500Kv and a 52MM aluminum Prop. I added the 10 Capisitor capbank I build to the setup and have been running flawlessly. Now I would not trust this to a real full Psetup or a hot P LTD setup. I am running the CoolRC 90Amp ESC the low prifile made it work in my boat. Later in the year I will replace with a MGM when I can afford it.
    Randy
    BBY Racing
  17. #47
    Apr 2018
    OZ
    276
    Here are two i have converted for mine but haven't used them yet still building my Mystic 138.
    Used the silicon conformal coating to water proof the board, see how it goes, i have used the XLX in a Slash 4x4 speed rig and went up to 378 amps
    and i love the data loging it is very easy to use
  18. #48
    Dec 2010
    3,117
    we have gotten 330 -350 amps on 8s,,, out of our XLX in cars ,,, The XLX is a way better esc , then the XL2
  19. #49
    Dec 2010
    3,117
    Quote Originally Posted by Speedfreek View Post
    Used the silicon conformal coating to water proof the board see how it goes, i have used the XLX in a Slash 4x4 speed rig and went up to 378 amps
    Man I like that !!!!
  20. #50
    May 2007
    1,603
    Yeah they came out great. My buddy machined some plates for our Egde 200's and it made a huge difference in esc temp.
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
  21. #51
    Jul 2015
    638
    Those are cool ,what about cap banks? Needed on those?
  22. #52
    Jul 2015
    638
    Does your buddy have a CNC machine he can scan those plates and crank out some more?
  23. #53
    May 2007
    1,603
    I have never run a cap pack and so far I haven't needed them. I always check my ripple current and it's always been pretty low.
    My buddy did these on a small machine and we are looking to do a small run but I doubt he will sell them.
    Team Liquid Dash
  24. #54
    Apr 2018
    OZ
    276
    Thanks ,if a 40mm fan can cool this the water cooling will definitely make it a ice machine
  25. #55
    Apr 2018
    OZ
    276
    Quote Originally Posted by Raydee View Post
    That will work no problem and make it more compact as well, i have ample room in my 138 so i just milled the fins out and set the cooling blocks in ..
    Looking sweet
