Page 1 of 2 12 LastLast
Results 1 to 30 of 55
Thread: Mamba XL X
    Jul 2011
    AK
    19
    Default Mamba XL X
    Has anyone tried this new ESC in a boat? How about water cooling, is it simalar to converting the Mamba XL2?
    Dec 2013
    az
    1,228
    It's the same case as the xl2 so easy to convert to water cooling.. Does have 4 more caps that make overall length longer.. As far as performance.. I like the adjustable bec.. And running the 2 back to back it runs on average 30 to 40 degrees cooler than the xl2 with same exact setup in same boat and motor and prop..and have spiked it well over 275 amps.. Just wish they were a bit more waterproof
    Jul 2011
    AK
    19
    Thanks for the reply. One more quick question. How tall is the ESC after removing the heat sink and cooling fan and converting it to water cooling? I found some interesting comparisons of the xlx to the xl2 here
    http://www.rctech.net/forum/electric...lx-vs-xl2.html
    and here
    http://www.ultimaterc.com/forums/sho...d.php?t=229571
    Oct 2013
    la
    8,740
    Omg. Castle stopped selling the xl2 and replaced it with a neutered version. Bad castle. Very disappointed!!!
    This sucks.
    Oct 2008
    9,488
    Sounds like they are doing this for warranty reasons...
    https://youtu.be/foiRZU5UVTA
    Apr 2014
    KS
    241
    Yeah, as much as they advertise about being the "FASTEST" company in RC, I think us "boaters" are getting the short end of the stick here. Why did they stop making boat ESCs and when will they start to make them again?!
    They stopped the Hydra series several years ago. They stopped because they lost $$$ on every one due to all the warranty returns....close to 100 times the warranty claims versus airplane controllers. They should get props for hanging in so long.
    The neutering of the Mamba is a disappointment, but I use the aircraft controllers modded for boat use. They make
    wonderful
    controllers as long as they don't get wet.
    Apr 2014
    KS
    241
    I understand the warranty thing, but I (personally) would be reluctant to mod an airplane controller for boating use, if it can't get wet without failing, because that seems inevitable.
    They should change their slogan to: THE FASTEST NAME IN RC (except for boats).
    Cool
    The Hydras weren't tolerant of water either. Experienced boaters know how to keep water out of a boat. The Castles can be waterproofed (kinda) with CorrosionX if you doubt your skills. If you don't like Castle, don't buy one. No one is holding a gun to your head.
    Apr 2014
    KS
    241
    I'd like to see a boat lose it's hatch and not take on water...That's a good trick!!!....I have lots of Castle stuff..........................
    So, I know Castle COULD build a superior BOAT ESC if they WANTED TO. If warranty returns were your problem, then build it BETTER!
    They've become FAT & Sassy on their multi-MillionDollar TRAXXAS contracts and apparently don't care about boating as much, or expanding their line to encompass us all. It's about money, not the hobby anymore. GO TEAM CORPORATE AMERICA!!!!
    Jun 2015
    Wi
    734
    Quote Originally Posted by FORT-26 View Post
    Pretty sure if you have a $300+ controller, you probably have a fair amount of $$ into the boat and your going to make SURE your hatch can't come off. Sure, they could build a better controller, which would then raise the cost, and then people would complain about THAT too. Can't please everyone nowadays
    Dec 2013
    az
    1,228
    This sucks.
    they have fixed the firmware to bring it back to xl2 performance.. but I have blown 2 of them since.. time to try mgm
    Oct 2013
    la
    8,740
    Well that's good to know. What MGM are you looking at getting?
    Dec 2013
    az
    1,228
    Looking at the 280 lite with waterproofing for my q.. and probably the 400 for my t
    Jun 2012
    ny
    1,135
    Anyone convert the 160 HV lite controller to water cooling for a 10s setup it says good for 3s to 12s
    Cool
    I haven't, but it would be identical to what is done to the 200LV Lite. What many folks seem to forget is that high voltage setups don't run at higher amps. In fact a 10S setup will run with great performance with lower amps than a 4S setup. With better water cooling there is no reason that the 160HV would not make a great 10S controller.
    Improved cooling can extend the safe amp draw for a controller. An example was the old Hydra ICE 240 LV marine controller. It was identical to the aircraft ICE 200 LV (except for the firmware) yet was rated 40 amps higher. This was because the water cooling kept it...cooler. It is not high amps which cooks a controller, it is the heat.
    Jun 2012
    ny
    1,135
    sounds like a plan, I think I will get one for my 1/8 scale and convert it thanks very much Jay T
    Oct 2013
    la
    8,740
    Quote Originally Posted by rayzerdesigns View Post
    I have a couple of 250 lites and I was thinking about letting one go. One is brand new. Collecting dust.
    Dec 2013
    az
    1,228
    Are they the fully waterproofed ones??
    Mar 2008
    974
    I am going to try a 160 Brian water proofed for me in my 10s mono. I will let you know how it works out.
    Ray. I just got my TP motor and it looks good. I hope to have the boat done in a few weeks. Look forward to racing you guys again in the gas classes.
    Mark
    Jun 2012
    ny
    1,135
    Quote Originally Posted by MarkF View Post
    Mark
    can you please post some detailed pictures of your conversion? I have seen the ones Jay T done but would like to see different ideas out there thanks, geno
    Mar 2008
    974
    I am using an old Peter Zicha mount for the motor mount but had to drill new holes because these motors come with a 6 bolt star pattern. I'm sure you can use any motor mount designed for 5" rails but might need to drill some new holes unless you can get them to make the right bolt pattern. I will show pics once the motor is installed.
    I'm using the 5860 5y 650kv motor in hopes to be able to swing gas props at a little higher rpm than they do.
    Mark
    Dec 2013
    az
    1,228
    Mark
    Which motor did u get?? I got the 5860.. it's a amp hog.. did 2 laps and it popped a 300 sf speedo.. that was on a small prop.. not sure the cox will hold up.. thinking mgm 400
    Mar 2008
    974
    I have a 300 SF that's been through many motors and still keeps running. I got the motor listed above.
    Mark
    Jul 2007
    or
    1,088
    I have an XL X on the way. I'll be interested to see what it's capabilities are and what it will take to cool it.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    Dec 2013
    az
    1,228
    Quote Originally Posted by raptor347 View Post
    It's the same board as the 160.. but it has the bec.. the xlx is the one I blew up at nats in my q mono brian
    Mar 2008
    974
    Ray it sounds like your 300 was ready to go. These are 6 pole motors and they are going to be harder on esc than a 4 pole. That's one reason I went with 650 kv to get rpm down and prop size up.
    How do you water cool your castles? Have you seen how Brian does it?
    Mark
    Dec 2013
    az
    1,228
    I have seen how brian does it.. we just drilled out case and added 2 cooling lines per side
    Jun 2011
    ct
    826
    Default mamba xlx
    Mark
    if razordesigns popped a swordfish 300 on a small prop, do you think a 160 will handle it? how many amps are you anticipating?
    Jul 2007
    or
    1,088
    Some esc's are underrated, some are overrated.
    NAMBA FE Chairman
