Running such a large obsolete hull on 6S will be a mistake. Huge wetted surface and high weight means it will take a lot of power (amps x volts) just to get it on plane. These hulls are not known for low drag or high speeds. Amp draw will be very high, a minimum voltage should be 8S and 10S is better. On 6S the amps will be Almost twice of the draw you will see on 10S.
Even if you just want a play boat, it is no fun if it won't plane off, or if you keep burning up equipment. This is not a ground-breaking project, some of us run big cats and monos, and we have learned a thing or two. Those who only read about them, not so much.
Feel free to ignore the above. It's your money.
