Results 1 to 3 of 3
Thread: GSX380 Build Questions
    Feb 2011
    OH
    125
    Default GSX380 Build Questions
    Hi guys, need a little help here. I am still building the boat, so nothing is mounted yet. I know what Mike used on his original build for power. This is what I was thinking of using.
    Motor-4076 1700kv
    ESC-220Amp SF
    Cells-5s2p 6000-8000mAh
    Total RPM unloaded=31450
    What would be a good starting point on prop diameter? I have read that anything less than 50mm would be to small. That still makes it a Q sport hydro running 5s right?
    JAE 45 FE, DF Vortex 24, PB Mystic, Aeromarine Sprint Cat 42, Aeromarine Sprint Cat 36
    OH
    1,585
    Yes "Q" I would start with a x447 and go up from there. We can work on it at the pond.
    Feb 2011
    OH
    125
    Thanks Howard.
