Page 48 of 81 FirstFirst ... 38464748495058 ... LastLast
Results 1,411 to 1,440 of 2430
Thread: The official 36" zelos twin modding thread
  1. #1411
    4,100
    I don't believe the OP is having an issue with shipping from OSE, they were out of stock at the time, so he looked elsewhere. Pretty sure he ordered from Wohlt.
  2. #1412
    199
    Got my first 447 detounged. Probably not as good as some of the pros on here but it's balanced and it will cut
  3. #1413
    Mar 2016
    BZ
    970
    Every time I see a set of prepped x447s I gotta ask how da hell do you all get such a nice smooth curve. I'm cheating next time, Dasboata I'm coming!!
  4. #1414
    199
    I rough shaped it w a dremel that has a stone bit in it. Then finished w a file then emery paper file
  5. #1415
    199
    Got 60 this morning. X442 s&b struts at 3mm 2-3s batteries all the way forward. Probably could have got more but I can't seem to get the hull planted good bow wants to bounce. Thought lowering the struts to 3mm w the batteries all the way forward would help but no such luck
  6. #1416
    May 2016
    300
    Quote Originally Posted by REDLINE1 View Post
    Try reversing prop rotation to outward spin, helped my bounce problem a lot. ( if you do that don't forget to swap flex shafts). You want to keep struts as level as possible, I also have a small air damn that helped a little. What batteries are you using? btw, don't forget to change batteries in GPS ( your running low)
    Zelos 36 stock 68 mph
  7. #1417
    May 2016
    300
    Quote Originally Posted by Keagan-Z06 View Post
    It is not that hard to do it, its hard to get all 4 blades the exact same lol. I cut one 1st then used modeling clay to imprint the cut blade, baked it hard and used it as a templet for the other 3. I saw a vid on it and it worked out great.
    https://www.youtube.com/watch?v=OtEIhWQtxVo Might want to start it 1 min into it.
  8. #1418
    199
    No haven't tried that. Will do thanks. Running 2 reaction 3s, 50c 5000mah. Gps is recharging as we speak
  9. #1419
    199
    Quote Originally Posted by Team Lucas View Post
    I didn't have any clay so I used masking tape to make a template of the first blade then transferred it to the other three
  10. #1420
    May 2016
    300
    Two 6s forward. Only 4300 mah and 40c, but 3/4 pound liter and easier to adjust CG. Weight ver's power is my thinking. Find out tomorrow at the pond :)
  11. #1421
    May 2016
    300
    don't know why all my pics are upside down, sorry for that
  12. #1422
    199
    Keep us posted
  13. #1423
    May 2016
    300
    Ok just got back after trying out 4300 mah 40c constant 80c burst 2x 6s batteries all the way forward. Today was hard to compare last weeks runs with 4x 3s 5000mah, very windy today, but the boat settled down better and still had speed. Flipped it twice hitting a wicked cross wind, going into turn 1. 1st flip was 66.6 mph, 2nd was at 64.6. no damage, no battery shift
  14. #1424
    Jun 2016
    Oh
    44
    Finally heard from Jeff. My drive cables haven't even shipped yet and won't til at least tuesday. That sucks!!!
  15. #1425
    May 2016
    300
    Quote Originally Posted by Crazykev View Post
    It does suck:) not to be on Jeff's side, but I been emailing him back/forth since I ordered mine and learned that he has a hard time lately getting the collets. No since sending out shafts if there's no way to use them. I just got mine today, and for a guy to do this on the side and it not be his main income, Wow...he packs them in a tube no carrier can bend/ruin unless they blow it up lol. Very nice shafts, haven't fit them yet but I haven't seen any others post review on them, so I will start fitting them in tonight and try out this sunday
  16. #1426
    199
    Anybody running detonged S&B X442's? What speeds are you seeing? Ran 60mph last weekend w tonged S&B X442's.
  17. #1427
    May 2016
    300
    your making the face of the prop smaller, might get a higher RPM, but I think you will loose speed.
  18. #1428
    Apr 2016
    451
    On the contrary. At speed you are mostly using the blade tips, the tounges at speed will drag slightly reducing top end speed. The tounges are good for holeshot/bite. Not only that but you are creating a lighter flywheel by de-tounging. I want to say stock on de-tounged, sharpened, balanced and polished 442s mine ran low-mid 60s.
  19. #1429
    2,908
    Detongueing a prop will give you higher speed, with higher RPM.
    The tongue on a prop gives you more pull out of a corner when racing.
    Without it, it may take a little longer to achieve speed, but it will be more, because the motor sees less load, therefore higher RPM.
  20. #1430
    199
    Thanks guys! I guess I'll keep my 442 tongued. I have a set of 447's detongued if I want to play around . I was just leery of the larger props with the potential for added heat and messing something up. I know there are a lot of guys running the 447's seems like you can get close to the same performance with the X442's
  21. #1431
    2,908
    Also by detongueing a prop you actually raise the pitch a little bit.
    A X442 has a 1.4 pitch ratio.
    Pitch ratio is a average pitch measured from the leading edge to the back edge of the prop.
    Seeing that the tip on a prop is a lot less pitch then the 1.4 ratio, after removing it, the average pitch ratio goes up.
    I have measured some of my detonged props, the come out at about 1.43 ratio.
    X442 = 58.8mm pitch
    X442 Detongued = 60mm pitch
  22. #1432
    Dec 2010
    3,116
    X442 = 58.8mm pitch
    I can't agree with this Larry you unless you are physically bending the blades on a prop,,, pitch does not change by removing the tongs,, your gauge might indicate that, but that pitch change you are seeing is from a slight change in how your gauge was set up,, or measuring the other blade.. getting exact pitch is difficult and time consuming now if you change the diameter of a prop the pitch ratio will go up but not the pitch
  23. #1433
    May 2016
    300
    I been using my 447's DT with no heat problems
  24. #1434
    Aug 2010
    uk
    2,887
    Yep pitch is pitch, Unless you physically alter the angle of the blades a prop still has the same pitch.
  25. #1435
    Jun 2016
    Oh
    44
    No, not with OSE! I ordered cables last monday from Jeff and still haven't received them, but ordered parts from OSE on Thursday night and received them yesterday! OSE hustles parts to me and have zero complaints. Ordered 45mm props, thrust bearings and a grease gun from OSE.
    Installed the thrust bearings:
    The couplers set screws were impossible to loosen without heating them up. I like seeing that because I know they aren't coming loose for sure! If I can heat something with a torch without ruining anything, I usually do if there is red locktite on the screw anyhow. Works every time!
    No shafts to install the props though I'm not trying to beat up on Jeff and totally understand why I haven't got them yet. I just wish the website said that this is a part time business and shipping may take a couple days because I would have ordered from someone else. I would have no issues at all if I hadn't broke a cable. I just hope they are worth the wait quality wise?
  26. #1436
    May 2016
    300
    Working on fitting my wire drives. They come long so I'm moving motor forward as far as they go, its not much (maybe 1/8th" or so) I don't see a problem with doing that?? I am also adjusting the height a little.
  27. #1437
    May 2016
    300
    Why thrust bearings at motor? I wasn't aware that theres drag there, we use to put them at the drive dog.
  28. #1438
    199
    Keep us posted on this waiting to hear how it works out Thanks
  29. #1439
    May 2016
    300
    Will do Should have some pics posted tonight, if I get a chance to finish one up. Hoping to use them this sunday.
  30. #1440
    May 2016
    300
    Ok guys, ones that want to run the wire drives from Wohlt's ill call them " Jeffs drives" lol. I finished fitting one in and very nice, but what a pain in the ass taking out the motor 6 times to adjust best position. I think if you follow what I did, it will save you some time. I hand twisted shaft while adjust motor, to feel the lease drag, so here it is for the adjustment for "Jeff drives"
