Page 58 of 81 FirstFirst ... 848565758596068 ... LastLast
Results 1,711 to 1,740 of 2430
Thread: The official 36" zelos twin modding thread
  1. #1711
    Jul 2016
    4,125
    Has anyone done anything to address the thickness, or lack there of, of the hull at the rear of the sponsons where the struts attach? I'm on a carbon reinforcement kick at the moment, and am debating a simple overlay approach on the inside or paying someone to cut some shims from carbon plate to sandwhich between the struts and the hull on the outside.
  2. #1712
    Jul 2016
    199
    I don't think the shims would make it any stronger. I think an overlay would be better I would like to do that myself. Don't know if you could just flood the area with a layer of epoxy or lay some glass cloth in . Either of which I have never done so I would need some education on what epoxy/ cloth to use. I was surprised how thin that area was when I was remounting the struts with silicon sealer, but what do I know, just seemed thin
  3. #1713
    Jul 2016
    4,125
    Using appropriately sized carbon shims should spread the load out over a larger area of the rear face, potentially all the way to the edges, but would add thickness to the assembly changing hardware and driveline length issues. I suppose it won't hurt anything to lay carbon cloth over that area on the inside and I won't have to alter any of the hardware.
    REDLINE, I'll cut you two extra pieces of carbon when I trace a pattern tonight. Then all you'll need is a little resin.
  4. #1714
    Jul 2016
    199
    Sweet thanks! as long as the screws are long enough to accommodate the increased thickness should be no problem.
  5. #1715
    Apr 2016
    Ca
    451
    I actually cut some shim plates out of 25gauge galvanized steel and marine epoxied in to brace the hull. It had some pretty bad spiderweb cracks that where starting to flake off. The thick marine epoxy doesnt look the greatest on the inside where I couldnt sand it but is for sure 3times stronger than stock. Its in this thread with pics a ways back. It works, dont see why the carbon wont. The clear epoxy will for sure look better and lay out better.
  6. #1716
    May 2016
    300
    I have a question for you electric guys. What gets hotter 1st, motor or esc's? seems like my motors are hotter then esc's. thinking of cooling motors 1st then the esc's. running 6s each.
    Zelos 36 stock 68 mph
  7. #1717
    Jul 2016
    4,125
    Quote Originally Posted by Team Lucas View Post
    I think it depends on the setup and how much throttle you use throughout the run. I cool my ESC's first, but after a prop change on my blackjack 29, my motor was hotter than the ESC. I swapped the cooling lines and everything was even again.
  8. #1718
    Jun 2015
    Wi
    734
    Does it "seem" like they are hotter, or are you reading them with an actual thermal gun?
  9. #1719
    May 2016
    300
    a gun and there 40 to 50 degrees hotter
  10. #1720
    ON
    2,917
    That is a big difference.
    What are your actual temp readings:
    ESC's - ?????
    Motors - ????
    Batteries - ????
    Larry
  11. #1721
    Jan 2015
    CA
    470
    ESC's - ?????
    Motors - ????
    Batteries - ????
    Larry
    I agree with Larry, but what are the actual temps. If the motors are 120* and the ESCs are 80*, I would not worry about it too much. But is your motors are 180* and your ESCs are 230*, then I'd worry.
    Also, are you running stock props?
    Rafael Lopez
    Product Developer-Pro Boat
  12. #1722
    May 2016
    300
    Quote Originally Posted by Rafael_Lopez View Post
    I am running x447's and I will take bat ,motor ,and esc's temp tomorrow.
    Thanks for replying guys.
  13. #1723
    May 2016
    300
    BTW Rafael. another guy at the pond liked mine so much, he bought one, that's 3 and counting :) Running a couple of them in a heat is impressive to watch.
  14. #1724
    Jul 2016
    4,125
    Must be tough to keep track of your own boat!
  15. #1725
    Jul 2016
    4,125
    What are your water temps like? I can't seem to find any of my temp data from the fall, but the local pond was probably mid 60's and I could run just short of 3min on 2 3S packs, stock electronics, x447 props, and the electronics we only warm to the touch. Even in the middle of summer, when everything ran hotter, I never saw the differences you're describing. I filed tear drops in front of each water inlet on the bottom of the hull, plumbed both ESC's in series before cooling a motor and then exiting the hull. I drilled out the water oulets with one size larger drill bit as well.
  16. #1726
    Aug 2016
    ON
    45
    well ran things the best way i could with the room i had.reallly tight in there.once again this was a project just to see if this would work so haters stay clear.setup it two custom wound 1.5x4 cordova motors that r 2700 kv each running 8s each so 16s total and i am using a futaba radio 4pks-super r for good range all powered by thunder power batteries.i also have the 48 inch zelos running a 1650 lehner 3040 on 10 s waiting to also test this summer.WILL SUMMER HURRY AND GET HERE LOL!!!!!!!!!!!!!!!
  17. #1727
    Mar 2016
    BZ
    970
    Looking forward to see this
  18. #1728
    May 2016
    300
    not when your in front
  19. #1729
    Jan 2016
    NV
    81
    Looks good. +1 on...I cant wait for summer.
  20. #1730
    Mar 2016
    BZ
    970
  21. #1731
    Dec 2016
    GR
    110
    Quote Originally Posted by Keagan-Z06 View Post
    Are those 4050?
    Genesis 36", Zelos Twin 36"
  22. #1732
    Mar 2016
    BZ
    970
    Sure is!
  23. #1733
    Dec 2016
    GR
    110
    Nice nice,and kv? Im thinking of those also on 2100
  24. #1734
    Mar 2016
    BZ
    970
    Just need to tidy up a bit now.
  25. #1735
    Jun 2015
    CA
    205
    Finally getting around to this project. Any recommendations on how to setup the fiberglass cloth and PT40 finishing resin before I do something wrong? Thinking of putting tape around the outside of the hills crack before laying in the glass and coating the rear.
    Also just noticed the left side steering cable is frayed should I replace it or grease it up good and let it ride?
    Thanks for any and all recommendations/tips.
    Brian
  26. #1736
    Jun 2015
    Wi
    734
    Quote Originally Posted by baller69 View Post
    Are those Ebay controllers?
  27. #1737
    Jun 2015
    Wi
    734
    Quote Originally Posted by ChevyPrerunner View Post
    I would definitely replace that cable it looks like its ready to let loose
  28. #1738
    Oct 2013
    la
    8,740
    I can't wait to see this!
  29. #1739
    Jun 2015
    Wi
    734
    Isn't that like 60,000 rpm per motor? I'm sure interested to see what happens
  30. #1740
    Aug 2016
    ON
    45
    Quote Originally Posted by Mxkid261 View Post
    me to LOL!
